Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
1x (3/4") default in window door trim
This is really basic, but it's amazing to me that the door and window tools do not have a 1x default (since they have a lot of other generally useless choices) in the USA version when selecting casing and brick mold trim.
1 REPLY 1
I think what is more important is to get back the "Rough Opening" check box under the Options tab or change the code. Now, if you enter the rough opening of a door the actual part will grow by the thk. of your jamb. This is ridiculous. window parts don't do that why should the doors.
I understand that in both our situations saving a favorite solves it. I agree with the intent that the parts should be a little better thought out.
