I have a couple wishes that I have been requesting for a couple years now.
1) Profiles are stored as Fills, and can be accessed in the Wall, Beam, and Column Tools. I would like a Trim button added. That way when I open a Door, Window, etc. then I have infinite number of casing that can be applied to the doors or windows. And they would update automatically when the doors or windows are adjusted. Within the Door or Window Tool, there should be 3 or 4 trim/casing options: inside side, inside head, inside skirt, exterior brick moulding, etc.
2) We need more Roof Accessory options. My preference would be to make the Skylight Tool a Roof Accessory Tool instead. This button would have skylights, roof vents, roof access hatches, roof drains, roof platforms for mechanical (cant flashing option), etc.
3) We need a lot more commercial library parts!!!! The product is currently way to residentially oriented.
4) Doors should have options for closers (which have ADA implications), kick plates, etc.
5) There are just WAY TO MANY people asking for the Stair Tool to be improved, and a lot of extra suggestions out there on how to do it!!! This is an integral building component and should NOT require the customer to pay for an AddOn to fix ArchiCAD's mistakes. Its time for ArchiCAD/Graphisoft to either fix the Tool, or purchase it from someone who has already done it correctly.
6) Ceilings in general: The Lighting library is a joke, both on the residential and commercial side. Every warehouse, storage room, etc has exposed fluorescent tube lighting.... except the AC library. Stop creating unique funky lighting objects when even the basic ones aren't present.
7) Window and Door Objects should have the ability to "hot link" or internally reference the jamb, sill, and head details, so if the details move on the sheets, the schedule updates. Or if a window is copy/pasted, then the schedule is already completed.
Please add Mesh Tools or Site tools. No building floats in space without a site, site access, parking, signage, site drainage, etc etc etc. Unfortunately all of the AC parts presume a flat site.
