Wishes
SOLVED!
Door Marker
Miliot
It would be very helpful to have an extra option in the door marker which can show HEAD HEIGHT of the door, by that i mean wallhole height + sill height.
I some cases, for the construction workers on site this information is very important for building wall openings. They don`t need to know those two dimensions separately especially when the sill is not load-bearing.
I know that you can make a custom label but it is not very reliable when you have doors in different directions or they are maybe in a slanted wall.
1 ACCEPTED SOLUTION
Solution
This may be possible to do currently.
You could create a Property that would calculate the Head Height of the Door using Expressions.
Then you could use the "Door Stamp 23" Door Marker to display its value.
Or you could use a Label to display it.
1 REPLY 1
Solution
