2007-06-27 10:46 PM
2007-06-27 10:53 PM
RichYoung wrote:I assume you are using Windows? I'm running OSX right now so I can't check that.
When you go file/open and open a project file folder….the files show in list format and do not show the date modified detail without changing the view menu again.
Is it possible to have the date modified view open as a default?
2007-06-27 11:41 PM
