Looking for beams to have fills in plan on some occasions & not in others - depending on quickview. (independant of other elements fills)
Also line type & pen should be adjustable per layer & per quick view
Looking to manually mitre ends of beams for clean plan view when abbutting walls or other beams at an angle (but not wanting to join/ merge with them)
Looking to have inclinable beams, that can also have eg steel section profiles in section views - yet that can be maniulated in plan as standard beams (yes I know you can use libray parts - but these don't aitomatically clean up, or interact with wall accessories the way beamss do).
Also elliptical & circular beams, and irregular shaped beams (as for walls)
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
