Thomas wrote:
Maybe this has been said elsewhere, or perhaps it should have its own thread, but if someone would outline how to create a toggle button for a toolbar (in AC9) to toggle between Hairlines and True lineweights, I'd be very happy!
This can only be done via an API add-on. But, the good news is:
The Windows version of a 9.0 add-on (QuickDisplay) to do this and more is ready. This is offered as
freeware to the ArchiCAD community in celebration (?!) of my 1,000th post here.
To read the documentation and download, go to:
http://www.archispectives.com/tools
I'm in the process of buying a used Mac from a fellow talker so that I can compile a Mac version. But, it'll be at least a couple of weeks before all of the pieces arrive. I'll announce the Mac version of the add-on when it is ready, Thomas.
Ideally, users of QuickDisplay should map the toggle hairline command to a shortcut key (I use "H" for Hairline). Pressing the key once switches to hairline; pressing again switches to true weight. Seems trivial, but it really speeds work. The add-on also has commands for several other display options.
Hopefully, I'll have the Mac version before too long.
This is for 9.0 only by the way.
Karl
PS Thomas is right that this is off the topic of this wish thread, so if you have any public comments/suggestions on this plug-in, please go over to this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=25724#25724
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
