Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Pet palettes logic
Rob
When adding or subtracting to a slab/fill/roof in the plan window with the free shape geometry method it is currently impossible to draw curved shape straight away. I think, it would be quite helpful to automatically replace the 'manipulation' palette (no.1 see att. image) by the 'curve/line drafting' palette (no.2) after putting the first point on plan.
::rk
5 REPLIES 5
Dwight
And, (whining), why can't the little "pets" be arrayed tightly around a central point so any function selection is immediatley accessible. (end whining)
Dwight Atkinson
Dwight,
I think for your tags to work correctly you need to use square brackets, and close your tag properly.
e.g. [whining] [/whining]
Dwight
Thank you.
I meant those as stage directions rather than a lame attempt at calling up those alleged "smileys" that are of questionable taste, anyway.
Like when Joseph Shambala, leader of the Ladysmith Black Bamboozlers says "sing" at the beginning of "Homeless"
Dwight Atkinson
Rob
and don't forget to vote while whinging/talking rubbish lads...
::rk
Done
