2020-08-17 01:48 PM
2020-08-18 11:36 AM
| Archicad 4.55 - 27
2020-08-18 12:37 PM
2020-08-19 02:13 PM
| Archicad 4.55 - 27
2020-08-19 05:29 PM
Miha_M wrote:Yes! That's the spirit.
Nothing to thank for here, we are all trying to make Archicad even better.
My goal is to utilize the SEO operations to easily pull data from the model.
Here is a single mesh with Add and a Subtraction operations.
The operators are hided by layer.
Note that the geometry of the Original Terrain maintain the operations even with the operators hided.
If I pull the NetVolume and GrossVolume of the mesh, they will reflect these operations.
The geometry of the Infill and the Excavation are much more simple than copying and editing the original mesh. Not to mention that it would add a lot more polygon to the file.
If we could control the SEO operations weather it is an Existent/Demolished or a Simple Existing View would make not only the modeling easy, but also the extraction of quantities.
To refine this feature (And this would be the cherry on top of the cake) there could be 2 new Global parameters to extract from an element, namely: AddedVolume and SubtractedVolume.
2020-08-20 12:57 PM
| Archicad 4.55 - 27
2020-08-20 04:45 PM
