Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Thickness to a mesh
Yvonne
It would be good to be able to apply thickness to a mesh when modelling a slab with multiple levels... instead of having 2 meshes and doing a SEO to get the thickness
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
12 REPLIES 12
Lingwisyer
Guru
Could you just put the spots on the reference mesh which you turn off in 3D views?
Yvonne wrote:
Is it possible to drop spot levels on it?
I don't think so as it is an object.
Unless the original mesh stays there then you can add levels to that.
I only ever had a quick look at it when the original post was made, so i don't know a lot about it.
Hmooslechner
As posted before, i think , this is an interesting workaround over GDL: https://archicad-talk.graphisoft.com/viewtopic.php?f=49&t=70631
BUT - Why workarounds - Make it possible in the original Tool!
