2023-09-11
03:01 PM
- last edited on
2024-04-17
10:50 AM
by
Aruzhan Ilaikova
On the right column of this forum. There are Labels that must be chosen in order to post a topic. "Walls" are missing from the list. Why? Beams, railings and columns are on there. Also, could the list be put in alphabetical order or at least grouped into smaller related fields with visual separators?
Solved! Go to Solution.
2023-09-11 08:06 PM
Your wish is our command. A Walls label has been added and your post has been set to use it. No doubt an oversight when things got set up... I believe the plan is/was to have all tools listed as labels here, so in the meantime just PM a moderator if you find something missing.
2023-09-11 08:06 PM
