2006-11-29 05:11 PM
2006-11-29 05:33 PM
2006-11-29 10:48 PM
2006-11-29 11:41 PM
2006-12-02 12:01 PM
Mike wrote:Another problem also, is I don't believe there is any way to label elements of a hotlinked module. I wish there was Or is there? Does anyone know?
We need a better solution for labeling windows and doors in elevation views.
2006-12-02 06:54 PM
Ray wrote:The only way I know is to label the elements in the module itself...not in the placed instance. Is there any reason why you don't do it this way?
...Another problem also, is I don't believe there is any way to label elements of a hotlinked module. I wish there was Or is there? Does anyone know?
2006-12-02 06:59 PM
TomWaltz wrote:Tom,
I have to add here (as I often do), that a lot of the problems with Labels is in the Objects themselves. If Graphisoft created cleaner labels that actually behaved, a lot of these problems would go away.
Personally, I prefer them being separated from the element. I find the Door/Window markers to be a real pain!
2006-12-02 09:17 PM
Dan wrote:Prior to build 1010, Labels sometimes would not appear in elevations/sections.
I'm currently finalizing my new "Builder Dimension" marker and I'm curious what specific problem behavior you're experiencing with Graphisoft's labels /markers?
2006-12-03 10:50 PM
Dan wrote:Sorry, Dan yes in plan, but I was thinking specifically of labelling doors and windows in elevations, and as the elevations can not be part of the module then I can't see any way of achieving this.
Dan K
2006-12-04 08:20 AM
Ray wrote:Ray,
...Sorry, Dan yes in plan, but I was thinking specifically of labelling doors and windows in elevations, and as the elevations can not be part of the module then I can't see any way of achieving this.
