2004-04-22 12:47 PM
2004-04-22 02:41 PM
2004-04-22 04:30 PM
2004-04-22 05:26 PM
2004-04-22 10:16 PM
cadaron wrote:firstly, i agree with you that the limitation of basic objects in the library make for some frustrating times, but slow down and think about this:
Thanks for the tip tom, we have tried this, it is cumbersome, it is another operation.
simpler to be part of the ID ref. that has already been set for the plan.
2004-04-23 12:22 AM
2004-04-23 09:16 AM
2004-04-23 02:28 PM
cadaron wrote:forgot about display options. doh!
thanks and yes, normally you only want door window labels for construction, but if you are using the display option settings together with quickviews then there isnt problem to have them off in presentation and on for construction.
again we have tried the label tool, but without success, plus the elevation ID must match the plan ID, which is already set for the plan, why go through the process again with a label tool?i think what i was getting at was the label tool current has the option to autolabel elements
2004-04-23 03:25 PM
