Archicad C++ API
How to filter open file type with DG Openfile?
Newbie
Is there anyone know with this DG::GetOpenFile() function, how to set its filter to be able to open only .pln or .pla type?
Joel Buehler
mmmh i can't find the GetOpenFile function in the documentation and neither in the DG_Test example.
are you maybe speaking of the Open File Dialog? Something like this:
When yes, the filter system for this dialog ist quite simple:
	//OPEN DIALOG UNISTRINGS SETTINGS
	const GS::UniString input = "Open Button... =)";
	const GS::UniString inputFilter = "Excel Files";
	const char* fileExtensions = "xls";
	//FILE TYPE MANAGER SETTINGS
	FTM::TypeID	retID;
	FTM::FileTypeManager ftman("xls");
	FTM::FileType type(nullptr, fileExtensions, 0, 0, 0);
	FTM::TypeID  id = FTM::FileTypeManager::SearchForType(type);
	if (id == FTM::UnknownType)
		id = ftman.AddType(type);
	//FILE DIALOG SETTINGS
	DG::FileDialog	dlg(DG::FileDialog::OpenFile); // Open only 1 file
	UIndex	i = dlg.AddFilter(id, DG::FileDialog::DisplayExtensions); // Force it on mac...
	dlg.SetFilterText(i, inputFilter);
	//INIT OF IO LOCATION
	IO::Location location;
	if (!dlg.Invoke())
		ACAPI_WriteReport("ERROR IN OPEN FILE DIALOG!", false);
	else
		location = dlg.GetSelectedFile();
                   // with the location you can start working on the file
You find this in a modified version in the DG_Test example 😃
Hi Joel,
From your code below, the fileExtensions parameter can be only "xls". Which recently it could be "xls" or "xlsx", so how could it filter with both format?
	FTM::TypeID	retID;
like this:
	FTM::FileTypeManager	ftMan("Exel Files");
	FTM::GroupID			gid = ftMan.AddGroup("Excel Old Format");
	ftMan.AddType(FTM::FileType("ExcelOld", "xls", '    ', '    ', 0), gid);
	FTM::GroupID			gid2 = ftMan.AddGroup("Excel New Format");
	ftMan.AddType(FTM::FileType("ExcelNew", "xlsx", '    ', '    ', 0), gid2);
	DG::FileDialog  flDlg(DG::FileDialog::OpenFile);
	flDlg.AddFilter(gid);
	flDlg.AddFilter(gid2);
results in this:
by the way: The Archicad API has the very cool excel capabilities since the paid version of the libXl library is a part of archicad.
https://www.libxl.com/
