2023-07-12 03:09 PM
Is there anyone know with this DG::GetOpenFile() function, how to set its filter to be able to open only .pln or .pla type?
2023-07-13 12:28 AM
mmmh i can't find the GetOpenFile function in the documentation and neither in the DG_Test example.
are you maybe speaking of the Open File Dialog? Something like this:
When yes, the filter system for this dialog ist quite simple:
//OPEN DIALOG UNISTRINGS SETTINGS
const GS::UniString input = "Open Button... =)";
const GS::UniString inputFilter = "Excel Files";
const char* fileExtensions = "xls";
//FILE TYPE MANAGER SETTINGS
FTM::TypeID retID;
FTM::FileTypeManager ftman("xls");
FTM::FileType type(nullptr, fileExtensions, 0, 0, 0);
FTM::TypeID id = FTM::FileTypeManager::SearchForType(type);
if (id == FTM::UnknownType)
id = ftman.AddType(type);
//FILE DIALOG SETTINGS
DG::FileDialog dlg(DG::FileDialog::OpenFile); // Open only 1 file
UIndex i = dlg.AddFilter(id, DG::FileDialog::DisplayExtensions); // Force it on mac...
dlg.SetFilterText(i, inputFilter);
//INIT OF IO LOCATION
IO::Location location;
if (!dlg.Invoke())
ACAPI_WriteReport("ERROR IN OPEN FILE DIALOG!", false);
else
location = dlg.GetSelectedFile();
// with the location you can start working on the file
You find this in a modified version in the DG_Test example 😃
2023-07-13
03:19 AM
2023-07-18
04:05 AM
Hi Joel,
From your code below, the fileExtensions parameter can be only "xls". Which recently it could be "xls" or "xlsx", so how could it filter with both format?
FTM::TypeID retID;
2023-07-15 10:56 PM - edited 2023-07-15 10:56 PM
like this:
FTM::FileTypeManager ftMan("Exel Files");
FTM::GroupID gid = ftMan.AddGroup("Excel Old Format");
ftMan.AddType(FTM::FileType("ExcelOld", "xls", ' ', ' ', 0), gid);
FTM::GroupID gid2 = ftMan.AddGroup("Excel New Format");
ftMan.AddType(FTM::FileType("ExcelNew", "xlsx", ' ', ' ', 0), gid2);
DG::FileDialog flDlg(DG::FileDialog::OpenFile);
flDlg.AddFilter(gid);
flDlg.AddFilter(gid2);
results in this:
by the way: The Archicad API has the very cool excel capabilities since the paid version of the libXl library is a part of archicad.
