Archicad C++ API
Return the language of the running archicad
Emkave
Good day everyone!
I have a problem with returning the language value of running Archicad.
I want to do something related to localization and stuff but for that I want to know firstly what language is used by the user.
Do you know any way of returning the language of an active Archicad session? I guess the methods may differ for pre 27, 27 and beyond versions, right?
Thanks in advance!
Operating system used: Windows 10
2 ACCEPTED SOLUTIONS
kuvbur
Try ACAPI_AddOnIdentification_Application()
API_ServerApplicationInfo AppInfo;
GS::UniString language = "";
err = ACAPI_AddOnIdentification_Application (&AppInfo);
if (err == NoError){
    language = AppInfo.language;
Structural engineer, developer of free addon for sync GDL param and properties
kuvbur
List of value
In AC26 and older:
err = ACAPI_Environment (APIEnv_ApplicationID, &AppInfo);
4 REPLIES 4
kuvbur
Hi, thank you for the solution.
However, the issue is - when I tried this on my device, it returned me INT value (international -> English, I assume).
I wonder what is the list of language tags existing there in archicad. Do you know where I can find that list?
Also, do you know how would that be written for versions older than 27? Like for 26?
kuvbur
List of value
In AC26 and older:
Setup info provided by author
