Archicad C++ API
This add-on cannot be validated. Please contact the distributor.
LeeJaeYoung
What's wrong?
------ Build All started: Project: Element_Test, Configuration: x64-Debug ------
[1/23] Compiling resources...
Element_Test.grc
Element_TestFix.grc
Microsoft (R) Windows (R) Resource Compiler Version 10.0.10011.16384
Copyright (C) Microsoft Corporation. All rights reserved.
[2/23] Building CXX object CMakeFiles\AddOn.dir\Src\APICommon.c.obj
[3/23] Building CXX object CMakeFiles\AddOn.dir\Src\APISpeedTest.cpp.obj
[4/23] Building CXX object CMakeFiles\AddOn.dir\Src\PropertyUtils.cpp.obj
[5/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Modify_Polygon.cpp.obj
[6/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Edit.cpp.obj
[7/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_SolidLink.cpp.obj
[8/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Modify_ChangeParameters.cpp.obj
[9/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Tools.cpp.obj
[10/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Test.cpp.obj
[11/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Trim.cpp.obj
[12/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Set.cpp.obj
[13/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Modify_Dimensions.cpp.obj
[14/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Hotlink.cpp.obj
[15/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Tips.cpp.obj
[16/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Batch_Create.cpp.obj
[17/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Modify_ModelElements.cpp.obj
[18/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Modify_2DElements.cpp.obj
[19/23] Building CXX object CMakeFiles\AddOn.dir\Src\Dumper.cpp.obj
[20/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Basics.cpp.obj
[21/23] Building CXX object CMakeFiles\AddOn.dir\Src\Element_Snippets.cpp.obj
[22/23] Building CXX object CMakeFiles\AddOn.dir\Src\UserItemDialog.cpp.obj
[23/23] Linking CXX shared library Element_Test.apx
Build All succeeded.
AC27 on window 11
Miha Nahtigal
Try running AC without licence (demo/readonly mode).
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Miha Nahtigal
Thank you so much ^^
AC27 on window 11
