3 weeks ago
- last edited
2 weeks ago
3 weeks ago
You can check new document or refer Examples code to find the changes then modify your code and solve the error one by one for AC27. For example, API_PenType is not used in AC27, you can find Example code in Attribute_test.cpp
HTH
3 weeks ago - last edited 3 weeks ago
I'm trying to upgrade the add-on to AC27 but I got errors while building the add-on
3 weeks ago
The file is in the following folder of API kit:
"\Support\Modules\CADInfrastructureBase\"
so please check whether you've added the path in your VS project settings.
HTH
3 weeks ago
I added the path but instead of fixing it from 9, I got 89 new errors. But the previews errors are gone. Does this error have to do with the API devkit? Because in version 26 it works fine.
3 weeks ago
Please try to add the path into your VS project Include Directory like below:
3 weeks ago
- last edited
2 weeks ago
Got it. But new errors appears
3 weeks ago
3 weeks ago
Can you tell me more about this "ACAPI_MigrationHeader.zip"? How will I know the correct name to use?
3 weeks ago
You can search the keyword then find the new name in this header file. for example,
3 weeks ago
- last edited
2 weeks ago
I tried including the ACAPI_MigrationHeader.hpp and now all my errors are in that file
