The content you are looking for has been archived. View related content below.
on
2019-09-16
10:00 AM
- edited on
2023-02-15
04:00 PM
by
Rubia Torres
| Archicad Formats | ||||||
| Archicad | BIMx | Teamwork | Library | PlotMaker | Diagnostics | |
| Other Formats | ||||||
| CAD | 3D/BIM | Vector Graphics | Image | Point Cloud | Video | Documentation |
import / export
| .PLN | Archicad Solo Project File |
Contains information about the project, associated files, metadescriptions, and other important content. |
| .PLA | Archicad Solo Project Archive File |
| Includes all library parts, linked images and textures. Import: File > Open > Open... Export: File > Save as... More details in this link. You can check Archicad file format compatiblity between different licence variations in this link. |
| .BPN | Archicad Solo Backup Project File |
Allows to recover the latest saved version of a damaged file. |
| .TPL | Archicad Project Template File |
Contains all project preferences settings, placed elements and tool default settings of the project. |
| .MOD | Archicad Module File |
Allows to insert the contents of external Archicad files into another project. |
| .2DL | Archicad 2D Line File |
| Allows to insert the contents of external Archicad files into another project. Import: File > Open > Open... Export: File > Save as... This option is only available in the 3D Window with the Vectorial 3D Engine - not available in OpenGL mode. |
| .MDE | Archicad Education Module File |
| Legacy This file format is no longer supported. |
| .PNE | Archicad Solo Education File |
| Legacy This file format was used in versions before Archicad 10. This file format is no longer supported. |
import / export
| .BIMX | BIMx Format |
| The BIMx model is known as a “Hyper-model”. The BIMx model can contain the full documentation of your Archicad project: the 3D model, plus any views, layouts and camera path. Export: File > Publish BIMx Hyper-Model... Can be opened by BIMx professional BIM project viewer. More details about BIMx in this link. In Archicad 20 or later the File > Save as command cannot be used for exporting BIMx Hyper-models any more. |
import / export
| .BIMPROJECT | BIMcloud (and former BIM Server) Import/Export Format |
| BIMPROJECT is the server data of one project. After importing this to the server you can work with the Archicad project in Teamwork. Archicad 14 and higher versions. Import: in BIMcloud Manager, more details here. Export: in BIMcloud Manager, more details here. |
| .TWTRAVEL | Teamwork Travel Package |
| The Travel Pack function creates a portable copy of your local data from the current Teamwork project. You can transfer project data and/or libraries in Archicad to a remote computer and continue working there. Import: Teamwork > Project > Traveling > Import Travel Pack Export: Teamwork > Project > Traveling > Create Travel Pack |
| .BIMLIBRARY | BIMcloud (and former BIM Server) Library Import/Export Format |
| BIMLIBRARY contains all the Library related data within a BIMProject Archicad 14 and higher versions. Import: in BIMcloud Manager, more details here. Export: in BIMcloud Manager, more details here. |
| .BCMB | BIMcloud Manager Backup Format |
| The BIMcloud Manager Backup format creates backup from all the information contained by the BIMcloud Manager application in its current state Import/export: More details about BIMcloud Manager Backup in this link. | |||
| .BCSB | BIMcloud Server Backup |
| BIMcloud Server Backups include all Teamwork data: Projects, Libraries, and their snapshots; Activity Log, mail and Server configuration information. Import/export: More details about BIMcloud Server Backup in this link. | |||
| .ARCHIVE | BIM Server Backup Format |
| Legacy Teamwork Backup format for Archicad 18-22 | |||
| .BACKUP | BIM Server Backup Format |
| Legacy Teamwork Backup format for Archicad 13-17 | |||
| .TWPACKAGE | BIM Server Import/Export Format |
| Archicad 13 BIM Server import/export format | |||
| .PLP | Archicad Teamwork Format |
| Archicad 12 and earlier version Teamwork format | |||
| .PLC | Archicad Teamwork Format |
| .PCA | Archicad Teamwork Format |
| .BPC | Archicad Teamwork Format |
import / export
| .LCF | Archicad Library Container File |
| LFC is a single file, that keeps all the objects used in your projects in one place, while keeping hierarchies intact within the LCF. Import/export: More details in this link. |
| .GSM | Archicad Library Object |
| GDL are usually created and used as binary objects with GSM extension. Import/export: More details in this link. |
| .GDL | Archicad Library Object |
| GDL file can be used to load attribute definitions, define line types, and materials etc. Import/export: More details in this link. |
| .DOR | Archicad Library Object |
| Archicad 8 and earlier version Library Object | |||
| .WIN | Archicad Library Object |
| .LMP | Archicad Library Object |
| .RSM | Archicad Library Object |
| .LSM | Archicad Library Object |
| .ISM | Archicad Library Object |
| .ESM | Archicad Library Object |
| .GPS | Archicad Library Object |
import / export
| .PMK | PlotMaker Drawing |
| In Archicad 9 and earlier versions the layouts were saved into a single PMK files that PlotMaker layouting program handled. More details about PlotMaker in this link. |
| .LBK | PlotMaker Layout Book |
| The Layout Book was introduced in PlotMaker 9, which had the LBK files. Since Archicad 10 it is intergrated into Archicad. More details about PlotMaker in this link. |
| .STB | Plot Style Table File |
| This file format is no longer supported. | |||
import / export
| .RPT | Crash Report File |
| Contains report about bugs, errors, crashes or other incorrect functionality of GRAPHISOFT products. More details about Bug Reporter in this link. |
| .REP | Bug Reporter Format |
| .SUPPORT | Solo Project Support Package |
| The package captures the current state of your project and includes other data that will help the GRAPHISOFT team to efficiently investigate troubleshoot the problem. Export: Help/Create Support Package... More details about Support Package in this link. |
| .TWSUPPORT | Teamwork Project Support Package |
| The package captures the current state of your Teamwork project and includes other data that will help the GRAPHISOFT team to efficiently investigate troubleshoot the problem. Export: Help/Create Support Package... More details about Support Package in this link. |
import / export
| .DWG* | Drawing Database File |
| DWG is used for storing 2D and 3D design data and metadata. Import: File > Open > Open... Export: File > Save as... More details about DXF/DWG Translation Setup in this link. |
| .DXF | Drawing Exchange Format |
| Enables data interoperability between AutoCAD and other programs. Import: File > Open > Open... Export: File > Save as... More details about DXF/DWG Translation Setup in this link. |
| .DGN* | MicroStation Design File |
| MicroStation is a CAD software product for 2D and 3D design and drafting, developed and sold by Bentley Systems. Import: File > Open > Open... Export: File > Save as... |
import / export
| .IFC | Industry Foundation Classes File |
| IFC is neutral file format that makes it possible to exchange information between different CAD systems and other systems in the building and facility management sectors. Import: File > Open > Open... Export: File > Save as... More details about IFC in this link. |
| .IFC (structural) | Industry Foundation Classes File (for Structural Analysis Model exchange) |
| Exchanging Structural Anlysis Model via IFC 2x3 format is supported. Currently, this functionality is an experimental feature within Archicad. Import: File > Open > Open... Export: File > Save as... More details about IFC Structural Anlysis Model export/import in this link. |
| .IFCXML | Industry Foundation Classes XML |
| IFCXML is recommended for architects whose partners’ applications cannot read the original .IFC format, but can manage .XML databases. Import: File > Open > Open... Export: File > Save as... More details about differences in IFC formats in this link. |
| .IFCZIP | Industry Foundation Classes ZIP |
| IFCZIP is the compressed version of both the normal and the XML-type formats, resulting in file size that is, on average, one-quarter of the original (file size varies depending on model size). Import: File > Open > Open... Export: File > Save as... More details about differences in IFC formats in this link. |
| .BCF | BIM Collaboration Format |
IFC-based data exchange can be enhanced by using the BIM Collaboration Format BCF-based communication. Export: More details in this link. |
| .SAF (.xlsx) | Structural Analysis Format |
| This file format enables collaboration with Structural Analysis Software. This open format was developed by multiple Nemetschek brands in order to enhance integrated practices. Import: File > Open > Open... Export: File > Save as... More details about SAF on this link. |
| .NWC | Navisworks Model File |
| Exports whole-project models for simulation and analysis in Navisworks. Export: Download Autodesk add-on (up until Archicad 19) using this link. Download Navisworks Connection Add-on for Archicad 21 and newer in this link. |
| .SMC | Solibri Model Checker File |
| Exports whole-project models to Solibri Model Checker. More details about Archicad and Solibri Model Checker in this link. |
| .C4D | Cinema 4D File |
| Cinema 4D Exchange is Maxon’s high‐end 3D modeling, rendering and animation solution, which is tightly integrated with Archicad. The connection between the two applications, using the C4D format, offers a streamlined 3D design workflow. Import: More details on loading Cinema 4D material in this link. Export: Document > Creative Imaging > PhotoRendeting Settings > Export to Cinema 4D. More details in this link. |
| .3DM | Rhinoceros 3D File |
Archicad is able to read and write native Rhino 5 3DM file format, enabling a “reference model” workflow between the two applications. |
| .3DS | 3D Studio Scene File |
3DS files are created with 3ds MAX 3D modeling, animation, and rendering software. With Archicad it is possible to import and export 3DS files. |
| .ATL | Artlantis Render Studio 6.5, 7 Files |
Artlantis is the fastest, stand-alone rendering application developed especially for architects and designers. Archicad exports the model in the Artlantis file format through its dedicated plug-ins. |
| .KML | Keyhole Markup Language File |
KML is an XML notation for expressing geographic annotation and visualization within Internet based, 2D maps and 3D Earth browsers. KML was developed for use with Google Earth. |
| .KMZ | Zipped Keyhole Markup Language File |
| KML files are very often distributed in KMZ files, which are zipped KML files with a KMZ extension. Import: File > Open > Open... Export: Available only in 3D Window: File > Save as... More details in this link. |
| .SKP | SketchUp File |
SketchUp is a 3D modeling computer program. It is useful from the earliest stages of design to the end of construction. |
| .DAE | COLLADA File |
| COLLADA (Collaborative Design Activity) is an interchange file format for interactive 3D applications. COLLADA documents that describe digital assets are XML files, usually identified with a DAE (Digital Asset Exchange) extension. Import: File > Open > Open... Export: Available only in 3D Window: File > Save as... |
| .EPX | Piranesi File |
| Piranesi is an interactive paint system that enables the user to create artistic images from 3D scenes created using conventional modeling applications. Piranesi uses the proprietary EPX file format. Export: Available only in 3D Window: File > Save as... |
| .FACT | Electric Image File |
| The Electric Image Animation System (EIAS) is an eminent 3D animation and rendering package. FACT files can be created with this program. Export: Available only in 3D Window: File > Save as... In Archicad Fly-Through and Sun Study can be saved into this format. More details about Fly-Through and Sun Study. |
| .OBJ | Wavefront File |
| OBJ is a geometry definition file format first developed by Wavefront Technologies. The file format is open and has been adopted by other 3D graphics application vendors. The OBJ file format is a simple data-format that represents 3D geometry alone. Export: Available only in 3D Window: File > Save as... |
| .STL | StereoLithography File |
Stereolithography (SL) is one of several methods used to create 3D-printed objects. STL (Standard Tessellation Language) is one such file type and is the language most commonly used for stereolithography. |
| .U3D | Universal 3D File |
U3D (Universal 3D) is a file format for 3D data. It is a standardized 3D data format with the purpose of facilitating 3D data exchange among programs of various kinds. |
| .FBX | Filmbox File |
Within Archicad, The Twinmotion add-on for Archicad allows you to export your Archicad 3D model to FBX. The add-on is installed by default. |
| .TMA | Twinmotion File |
Legacy file format that was used by the Twinmotion Add-on until Archicad 20. From Archicad 21 interoperability is provided using FBX format. |
| .WRL | VRML File |
| VRML (Virtual Reality Modeling Language) is a standard file format for representing 3D interactive vector graphics. VRML files are in plain text and have the WRL extension. Export: Available only in 3D Window: File > Save as... In Archicad Fly-Through and Sun Study can be saved into this format. More details about Fly-Through and Sun Study. |
import / export
| Portable Document Format File |
| PDF is a file format designed to present documents consistently across multiple devices and platforms. It was developed by Adobe 1992 and has since become one of the most widely used formats for saving and exchanging documents. A PDF file can store a wide variety of data, including formatted text, vector graphics, and raster images. Import/Export: More details in this link. Photo Rendering can be also saved to this format. |
| .DWF | Drawing Web Format File |
| DWF is a secure file format developed by Autodesk for the efficient distribution and communication of rich design data to anyone who needs to view, review, or print design files. Import: File > Open > Open... Export: File > Save as... DWF 6.xx versions are currently not supported. |
| .EPS | Post Script File |
| This file format is no longer supperted since Archicad 10. | |||
import / export
| .BMP | Bitmap Image Format |
| Import: Can be linked into Archicad as Drawing Export: File > Save as... Photo Rendering, Fly-Through and Sun Study can be also saved to this format. More details about PhotoRendering, Fly-Through and Sun Study. |
| .DIB | Device Independent Bitmap File |
| Import: Can be linked into Archicad as Drawing | |||
| .RLE | Run Length Encoded Bitmap File |
| .JPEG | Joint Photographic Experts Group File |
| .JPG | Joint Photographic Experts Group File |
| .JPE | Joint Photographic Experts Group File |
| .JFIF | JPEG File Interchange Format |
| .JP2 | JPEG 2000 Image |
| .GIF | Graphics Interchange Format |
| .TIFF | Tagged Image File |
| .TIF | Tagged Image File |
| Import: Can be linked into Archicad as Drawing Export: File > Save as... |
| .PNG | Portable Network Graphics Format |
| .PCT | Macintosh Picture Image File |
| .ICO | Windows Icon File |
| .HDR | High Dynamic Range Image File |
| In HDR image format raster images or digital photos can be saved. Import: Can be linked into Archicad as Drawing |
| .EXIF | Exchangeable Image File Format |
| EXIF is based on JPEG, stores the image information, but additional metadata as well, such as date, time, camera settings etc. Import: Can be linked into Archicad as Drawing |
| .LWI | Lightworks Image File |
| LWI is an image file format developed by Lightworks Design Ltd. Import: Can be linked into Archicad as Drawing |
| .WMF | Windows Metafile |
| .EMF | Enhanced Windows Metafile |
import / export
| .XYZ | Point Cloud File |
| The Point Cloud XYZ file format have 6 data (3 coordinates and 3 RGB data). Import: File > Interoperability > Import Point Clouds More details in this link. |
| .E57 | Point Cloud File |
| E57 files can be imported into Archicad to display Point Clouds in floor plan, section, elevations or 3D. Import: File > Interoperability > Import Point Clouds More details in this link. |
import / export
| .MP4 | MP4 Movie File |
| Export: Document > Creative Imaging > Create Fly-Through.../Create Sun Study... More details about Fly-Through and Sun Study. |
| .MOV | Apple QuickTime Movie File |
import / export
| .DOC | Microsoft Word Document Format |
| Export: Available only in Schedule Window: File > Save as... Interactive Schedules can be saved to this file format. |
| .XLS | Microsoft Excel Worksheet Format |
| Import/Export: More details in this link. Interactive Schedules, Energy Performance Reports can be saved to this file format.‘Mass property value import’ functionality is a semi-automated way to import data from an Excel worksheet into Interactive Schedules. More details on property value import in this link. |
| .XLSX | Microsoft Excel Worksheet Format |
| Import/Export: More details on this link. Interactive Schedules, Energy Performance Reports can be saved to this file format.‘Mass property value import’ functionality is a semi-automated way to import data from an Excel worksheet into Interactive Schedules. More details on property value import in this link. |
| .TXT | Text File |
| Interactive Schedules, Lists, Energy Performance Reports can be saved to this file format. | |||
| .PLT | HPGL Plot File |
| Plotter drivers shipped with Archicad all use the HPGL vector-graphic language. Export: File > Interoperability > Merge... More details about Plot in this link. |
| .LIC | Binary List Criteria File |
| Import: Can be added to Archicad as a library part in Library Manager. | |||
| .LIS | List Setup File |
| .PHPP | Passive House Planning Package |
| PHPP is the official Excel Workbook created by the Darmstadt Passivhaus Institute, to calculate the energy demands of Passivhouse projects. Export: More details in this link. |
| .GBXML | Green Building XML File |
| The industry standard Green Building XML format (gbXML) is recognized by several energy analysis applications such as Green Building Studio, Ecotect or IES. Export: More details on this link. |
DWG*: Archicad might not be able to read some elements that are part of a DWG file but are created with native tools of a specific software. For example: Walls created with AutoCAD Architecture won't transfer to Archicad via DWG export-import.
DGN*: Currently, it is only possible to import MicroStation files up to v7 DGN version.
I would like to draw your attention, that there are missing links in:
FBX is not available anymore
