ananas
BIMX export with saved 3D view
Hi!
3D view is not available after exporting to BIMX. I only see 2D plans.
I know there should be some option to click for 3D view, but I can´t find it.
Can someone please attach a printscreen of this option, please?
I use Archicad 26.
Thank you!!
Operating system used: Windows 11 Pro 23H2
1 Solution
CWagner
Hi ananas,
please make sure, that you did not only export a selection in the BIMx publisher set. You need to export the whole content of the publisher set.
If you only export a selection the BIMx Hyper Index will still show all of the names of the added views of your original publisher set. However, since you did not export all the 2D und 3D views, there will be missing views in your BIMx model.
Addition:
Exporting a selection can be used to update an already existing BIMx model.
Kind regards
Go to post
6 Replies 6
Did you include a 3D view in the publisher set for your hyper-model?
ananas
Hi, yes I did, but it gets placed on the layout, not being viewable as 3D
Your Publisher set properties are set like this? ...
ananas
Hi!
yes, I think is correct
Publisher settingsPublisher settingsBIMx ExportBIMx Export
in BIMX 3d Viewer I see 3D places on layout though, not as an actual 3D view.
BIMX viewerBIMX viewer
Ivan Myers
I'm having a similar issue.  Difference is my BimX model doesn't even populate the 3D views, Screen shot of the publisher set list attached.  Going to try and delete the current bimx set and re built the publisher set, then reload to the model transfer site.
Designer/ Drafter
ArchiCAD 26 on 27" Mac
CWagner
Hi ananas,
Addition:
Kind regards
