2015-02-20
05:27 PM
2023-05-09
03:42 PM
Noemi Balogh
2015-03-23 02:56 PM
2015-05-08 05:47 AM
Barry wrote:I did that but I am getting ar error message saying that it cant open the fie until I update. ?
Your BIMx Docs app should upgrade to BIMx Pro.
If it hasn't happened automatically go into you app updates and do it manually.
2015-05-08 05:58 AM
Steve wrote:Are you trying to open a BIMx file created in the version 19 Beta?Barry wrote:I did that but I am getting ar error message saying that it cant open the fie until I update. ?
2015-05-08 09:55 AM
2015-05-11 05:33 PM
Lennox wrote:I like that also because the most clients(homeowners); at least in my experience, want to see the floor plan & elevation. 2 sheets. Maybe a Pro BIMx Commercial & Pro BIMx Residential, maybe?
It seems a reasonable cost for large projects.
What about small domestic housing projects, (extensions / small alterations) of which I do many.
It would be good if there was a low cost option for these type jobs?
2015-05-19 10:17 PM
laszlonagy wrote:Still not clear on this...so in the instance shown here, is the BIMx Hyper Model identified as "BIMx Docs" or "Save to BIMx' (the 3D view used for the save) or possible "The Plastiras Residence"?
The BIMx Hyper Model is identified by the Name of the Publisher Set from which the model is created (this is the same Name the user sees in the Project List in the BIMx app). So the Hyper Model is not identified by the name of the resulting BIMx file. Therefore the name of the saved BIMX file can be freely modified to carry version/design option etc. information, and one does not have to pay the 50 USD each time the name of the BIMx file is different.
This is even true if you saved your Project file under a new name (e.g. in the SD, DD, CD phases) with the name of the Publisher Set staying the same.
2015-05-20 12:32 AM
2015-05-20 12:43 AM
2015-05-20 02:39 AM
2015-07-08 12:33 PM
