‎2013-10-21
04:14 AM
‎2023-05-09
02:57 PM
Noemi Balogh
‎2013-10-24 06:02 PM
‎2013-10-31 02:17 AM
‎2013-10-31 02:27 AM
Matthew wrote:I'm not sure this will be the solution to the problem.
For those following at home I received a reply from Graphisoft today;
"From the logs Csaba at Graphisoft has found that the problem is with the space in the username: (C:\Users\Firstname Lastname\...)
Graphisoft have corrected this issue in the code. The correction will be released in Hotfix 4.
Until then the upload will only work with a username which lacks "spaces". I hope this helps.
We apologise for the inconvenience."
So either change all of your user accounts in your offices to not use spaces in user names or wait until Hotfix 4.
‎2013-10-31 03:27 PM
‎2013-11-01 10:04 PM
‎2013-11-14 04:10 PM
‎2014-01-15 06:44 PM
KatalinBorszeki wrote:That makes no difference here. We are experiencing the same problem and have the correct hotfix set as default. Can save a local copy but not upload to Graphisoft. Also if we send our client a link to our locally saved updated file on Dropbox, which he then copies to iPad, the BIMx app asks him to pay for access to the model again. i wonder how Graphisoft thinks that makes us - and them - look in the eyes of a client? Rarely - if ever - have I seen a great idea so shoddily implemented!
HI, here is another reason that could often cause an upload problem. Bimx17 desktop has to be hot fixed to min version (4005)
When you open BIMx, make sure that the opened BIMx version is the hot fixed build (min) 4005. In certain cases more BIMx versions might be present on your computer. If you are on a mac, the default application to open BIMx (upon double-clicking a BIMx file icon) might not be the latest build you have on the computer!! You can change this setting, if you select a BIMx file on your desktop and hit "commandI" (info) it will bring up a dialog where the right build can be selected. Select build number 4005, and the uploading from BIMx desktop should go undisturbed. Thanks
‎2014-01-15 07:30 PM
KatalinBorszeki wrote:How do we hot fix a Bimx viewer on a windows machine? Is it included in the Archicad 17 hotfix or is there a separate one specifically for bimx?
‎2014-01-17 09:53 AM
macarchitect wrote:KatalinBorszeki wrote:That makes no difference here. We are experiencing the same problem and have the correct hotfix set as default. Can save a local copy but not upload to Graphisoft. Also if we send our client a link to our locally saved updated file on Dropbox, which he then copies to iPad, the BIMx app asks him to pay for access to the model again. i wonder how Graphisoft thinks that makes us - and them - look in the eyes of a client? Rarely - if ever - have I seen a great idea so shoddily implemented!
‎2014-01-17 01:25 PM
another Moderator
