No "Save As BIMx" Option?
I can save from BIMX to the .app or .exe files but I am unable to save to the .bimx file version for my iPad or anything else. It doesn't have just a "Save" option at all.
Any idea why? Thanks!
7 Replies 7
Only the latest hotfix (3267) for 15 can "Save" to BIMx format.
Have you installed that?
RandyC
I have seen the same problem , the save as bimx is greyed out for several
minutes , waiting and trying several commands in bim explorer brings the
two missing commands to where I can use them " save " and "share with the bim community" I am not sure what causes this delay and suspect a minor bug . I had mentioned this in an earlier thread.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Graphisoft just added this issue to the "Known Issues" page:
http://www.archicadwiki.com/BIMx/KnownIssues
The given workaround is to just wait for the commands to become enabled as mentioned by RandyC.
A strange one!
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Daniel Lindahl
I am very disappointed that the .app and .exe versions of BIMx are no longer available. I have not yet been able to make it work properly or send any files to clients for work in AC17.
BIMx works OK at the time when I save out the BIMx file, but if I try to open it later by double-clicking it, my new windows 8 laptop (bought specifically for AC17) says it cannot find the application to open the file even though BIMx was installed properly.
Also, whenever I save a BIMx file from AC17 my internet connection gets cut off, and I have to go to the Windows 8 troubleshooter to fix it.
I don't think the consequences of Graphisoft's changes to BIMx were fully thought through.
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
Hi Daniel,
See this poll:
http://archicad-talk.graphisoft.com/viewtopic.php?p=219562#219562
which was started from this thread...argh IOS 7 won't let switch tabs while editing.
Other thread
http://archicad-talk.graphisoft.com/viewtopic.php?p=219666
You can set the connetcion manually(right click and find the aplication), or run the BimX application first and then open the file from it.
Best Regards,
Piotr
