BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Print pdf from BIMx?
Mats Knutsson
Which of the BIMx variants can I print pdf from? I didn't find "print" in the web app nor the windows app.
/Mats
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
8 REPLIES 8
Roland Szabo
You can print from the mobile apps, and since last September, it's free. See this announcement in BIMx News. Here, you can also see we gradually added several features to the web&desktop apps in the last year; PDF export is next in line.
Roland Szabo
BIMx Product Manager
Hi @Roland Szabo is / will it possible to toggle disable / enable of the PDF export function when we Publish from Archicad?
We regularly give clients & other stakeholders a BIMx to review the full project and even have them use this as a base for feedback, etc.
But we need to be able to control if & when they can reproduce / distribute our drawings.
This was very possible & easy with the BIMx features before.
Regards Francois Swanepoel
Everything happens in Archicad since v6.5 (2000) ‌
Hiking, Motorbiking, Good food, Gr8! Beer & excellent conversation 😉
#MadeByDyslexia is my unfair advantage – expect curious ideas, creative big thinking & small typos.
<> www.fusionBIM.co.za <> www.Scirrus.co <> www.BIM2fusedVR.com <> (new) Anatomy of Archicad Course
@Ryleigh wrote:
Does the absence of a "print" option in both the web app and Windows app mean that PDF printing is not supported in those versions
Roland said in his post that PDF export (I assume printing) is next in line for web & desktop applications.
Roland Szabo
PDF export is already available on web&desktop, see BIMx News. PDF printing is supported by the PDF export feature. This way, you to customize the exported document's print settings on your computer according to your known and preferred method (instead of some limited print settings in BIMx).
Francois, does adding legal notes (or even watermarks) to your layouts address your concern? We don't plan to add such a PDF export control to the BIMx publishing settings of Archicad - which are used to define the content of Hyper-models. In the past years, anyone has had the opportunity to print from BIMx Mobile, e.g., with BIMx Pro Subscription purchased via Apple/Google or even without paying for it in the 2-week free trial.
Roland Szabo
I second this feature: I'm sure we've all encountered clients who need "persuading" from time to time to pay their bills promptly (or at all ! ). BIMx is an excellent means of sharing the project without giving direct access to the BIM model. A control on the ability to export, or not, PDFs contained in the BIMx file would be very beneficial.
(when working internationally, legal notes and watermarks can be as effective as a chocolate fireguard...)
AC28. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 15 Sequoia
Oleksandra Vakariuk
@TatumJaylen simply use the Ctrl+P shortcut. 🙂
Oleksandra Vakariuk
Technical Support Engineer
@TatumJaylen or you can use the Export to PDF function from the Menu.
brzmidobrze
We've observed that BIMx currently doesn't support vector PDF exports, which significantly limits its utility in our professional workflow. We would be immensely grateful if you could kindly advise whether there are plans to address this limitation in the near future, as it would greatly enhance our ability to deliver precise documentation to our clients.
I attached view of exported pdf.
