BIMx News
BIMx Updates
2026
Pro features on Web
2026. Apr 07. - BIMx Web 2026.7357 on BIMx Model Transfer and BIMcloud
Previously, we introduced Pro features on mobile and desktop versions. We continue unifying BIMx across platforms by adding Pro to the browser version, both on BIMx Model Transfer and BIMcloud.
The following Pro features will be available for members of eligible companies:
  • Hide and unhide 3D elements, and control multiple elements’ visibility with layers, layer folders, and layer combinations. Read more...
  • Customizable Cut Plane – slice 3D models parallel to any element surface to easily get a vertical, slanted, or horizontal cut. Read more...
Optimized BIMx Export from Archicad and MEP Designer
2026. Mar 26. - Archicad 29.1 4006 & MEP Designer 29.1 4006
As a component of Archicad 29.1 Update and MEP Designer 29.1 Update, we also optimized BIMx export: smaller files are exported faster, depending on project complexity. In BIMx, 3D models and layouts can be loaded significantly quicker, mainly on web and desktop.
2025
Parallel projection, Animations toggle, keyboard, mouse, and gamepad support
2025. Oct 01. - BIMx iOS&iPadOS 2025.6897, BIMx Android 2025.7060, BIMx Desktop (Windows 2025.7110, macOS 2025.7111), BIMx Web 2025.7162 on BIMx Model Transfer
  • Parallel Projection
    Switch between Perspective and Parallel projection in 3D. The default projection in BIMx depends on the 3D View Settings defined in Archicad.
    Available on iOS&iPadOS, Android, Windows, macOS, and Web on BIMx Model Transfer. Read more...
  • Animations toggle
    Disable 3D animations to speed up your workflows.
  • Keyboard, Mouse, and Gamepad support on Mobile
    External input devices are now supported on iOS&iPadOS, and Android platforms as well. Read more...
Customizable Cut Plane, One-Handed Walk Mode Toggle, Hide 3D Elements and Layers on Desktop
2025. May 21. - BIMx iOS&iPadOS 2025.6651, BIMx Android 2025.6590, BIMx Desktop (Windows, macOS) 2025.6620
This is the first update ever that includes Pro features on desktop (Pro was mobile only until now).
    Slice 3D models parallel to any element surface to easily get a vertical, slanted, or horizontal cut – without a section or elevation drawing.
    Pro feature, available on iOS&iPadOS, Android, Windows and macOS. Read more…
  • Hide Elements and Layers in 3D
    Pro features, previously released on mobile platforms and now on Windows and macOS. Read more…
  • One-Handed Walk Mode Toggle
    Option to switch between one-handed and the default two-handed controls in Walk mode.
    Available for all users on iOS&iPadOS and Android. Read more…
  • Increased camera rotation speed in two-handed Walk mode for easier navigation on iOS&iPadOS and Android.
  • Facelifted in-app icons on iOS&iPadOS for a more unified and modern look.
  • Required operating system increased on iOS&iPadOS from version 15 to 16.
  • Legacy skybox removed. BIMx's dynamic skybox was introduced in 2023. With the removal of the Lecacy skybox toggle, the old, static model background is not available anymore.
Hide 3D Elements and Layers on Android
2025. February 24. - BIMx Android 2025.6410
Hide 3D Elements and control Layer visibility functions are now available on Android, following the iOS&iPadOS release in 2024 October. This update also includes revamped (element, cut plane, and traced layout) context menus opening up more easily for a long tap. Read more...
2024
BIMx Web updated on BIMcloud 2024.4
2024. December 09. - BIMx Web 2024.6170 on BIMcloud SaaS
BIMcloud SaaS users can now also customize 3D navigation with the Adaptive rotation toggle that enables manual switch between orbit and rotate camera modes.
BIMx Web on mobile devices
2024. December 03. - BIMx Web 2024.6271 on BIMx Model Transfer
iOS and iPadOS version 18 enabled the web app on iPhones and iPads. The web app is still supported and optimized for desktop computers. Therefore, when opening it on any mobile device (including Android), a new dialog recommends using the Mobile app instead for a better experience. You can continue in the web app or download BIMx Mobile. See system requirements.
Hide 3D Elements and Layers, Improved 3D navigation, Entire layout book export
2024. October 02. - BIMx iOS 2024.6078, BIMx Android 2024.6115, BIMx Desktop (Windows, macOS) 2024.6142, BIMx Web 2024.6170 on BIMx Model Transfer, Archicad 28
This update includes the main new feature of 2024 – initially on iPhones and iPads:
  • Hide 3D Elements and control Layer visibility improve communication with even more interactive virtual models.
    • Hide and unhide elements and invert the current view – available in all 3D models
    • Control multiple elements’ visibility with layers, layer folders, and layer combinations – available in Hyper-models exported from Archicad 28 or later with the new "Use Layers in BIMx" publisher setting. Read more...
  • Revamped element, cut plane and traced layout context menus now also open for a long tap (in addition to single tap + blue dot).
Enhanced, more customizable navigation – iOS&iPadOS, Android, Windows, macOS and web
  • New Adaptive rotation toggle in Settings enables manual switch between orbit and rotate camera modes. Adaptive rotation: Automatic switch from orbit to rotate camera mode when entering the 3D model's bounding box. Read more...
Mobile (iOS, iPadOS, Android):
  • Invert horizontal and vertical axis toggles to adjust the direction of camera rotation
  • Refreshed joystick for convenient two-handed controls in Walk mode. Move the camera with one hand and rotate view with the other one, optimized for landscape orientation.
Desktop:
  • Export PDF function extended with entire layout book option (in addition to single page).
Android:
Customizable Cut Color, Issue Creation on Android, Easier Licensing
2024. July 04. - BIMx iOS 2024.5867, BIMx Android 2024.5890, BIMx Desktop (Windows, macOS) 2024.5910, BIMx Web 2024.5930 on BIMx Model Transfer
Cut Plane Color Picker – iOS&iPadOS, Android, Windows, macOS and web
Issue creation – added to Android
  • BCF-based markup tool for 2D&3D added to the other mobile platform. Read more...
Easier, company-level BIMx Pro licensing – iOS, iPadOS and Android
  • All members of eligible companies automatically access Pro features on mobile devices. Read more...
BIMx update on Apple Vision Pro
2024. June 19. - BIMx visionOS 2024.5789
The 3D model switch and anti-aliasing described below are also available on Apple Vision Pro. Smoother 3D element edges are noticeable not only in window mode but especially when exploring the 3D model in full immersion.
BIMx Web updated on BIMcloud SaaS 2024.2
2024. June 10. - BIMx Web 2024.5740 on BIMcloud SaaS
BIMcloud SaaS users now also access 3D model switch, anti-aliasing, architect credits, PDF export, and undo/redo.
3D Model Switch, Anti-aliasing, and more features in Web and Desktop
2024. April 18. - BIMx iOS 2024.5667, BIMx Android 2024.5700, BIMx Desktop (Windows, macOS) 2024.5720, BIMx Web 2024.5740 on BIMx Model Transfer
Mobile, web and desktop:
  • 3D Model Switch: New feature supports Design Options and in-context transition between 3D models saved with different Layer Combinations, Renovation Filters, Structure Displays, MVOs, and Graphic Overrides, easing model comparison. BIMx preserves the current view, sun setting, shading option, field of view, and cut plane while switching to a different model.
  • Anti-aliasing guarantees sharper, more realistic 3D representation with smoother edges. New toggle in Settings. Disable to slightly improve 3D performance. See enhanced visual quality on the right side with active anti-aliasing:
Web and desktop additional features:
  • Architect Credits are displayed while opening 3D models and remain visible in the 3D window's top right corner.
  • With the save PDF button, you can export layouts and images of 3D views as PDFs for e.g. printing.
  • Undo/redo: Easy navigation between previously opened layouts and 3D views.
BIMx Web updated on BIMcloud 2024.1
2024. April 18. - BIMx Web 2023.5411 on BIMcloud SaaS and On-Premises
BIMcloud SaaS users access these additional BIMx features:
BIMcloud On-Premises users on HTTPS connection now also access the next-generation BIMx Web app. This big upgrade includes the following improvements:
BIMx on Apple Vision Pro
2024. February 07. - BIMx visionOS 2024.5507
BIMx was released on the Apple App Store for Apple Vision Pro, just five days after the device’s official release.
The initial version supports full immersion mode and includes most BIMx features adjusted for Apple's new spatial computing platform.
2023
BIMx Web updated on BIMcloud SaaS 2023.4
2023. December 14. - BIMx Web 2023.5262 on BIMcloud SaaS
Updating BIMx to the next-generation app brings the following benefits for BIMcloud users:
  • Multiple times faster loading and smoother 3D navigation experience
  • Refined, modularized navigation system
  • Measure in 3D and on 2D layouts
  • Shading options
  • Shadows with date&time sun positioning and dynamic skybox
  • Interactive element labels on layouts
Favorite saving and Presentation in BIMx Web and Desktop
2023. November 20. - BIMx Desktop (Windows, macOS) 2023.5381, BIMx Web 2023.5410 on BIMx Model Transfer
  • Save your favorite layouts and model views with their current 3D settings (camera position, sun settings, cut, shading, etc.) and adjust the order of favorites where needed. Use favorites for easy navigation between parts of the documentation.
  • Play a presentation to hide every button from the interface, and enjoy animated transitions with an automatic switch. Presentation is available for favorites and also for gallery items (saved in Archicad).
Read more about these features in the How to Present with BIMx article, the BIMx Web user guide, and the BIMx Desktop user guide.
Transition to the new cloud licensing is complete
2023. November 15. - BIMx iOS 2023.5322, BIMx Android 2023.5350
This update includes the following changes:
  • The transition period to the new cloud licensing (introduced on 09.27) has ended. Now a BIMx Pro license needs to be assigned to your Graphisoft account to access Issue creation and BIMx API extensions. Membership (without license assignment) in an eligible company is not sufficient to enable these extra features anymore. Find useful details in the BIMx Licensing article.
  • The "Create Graphisoft ID" has been temporarily removed from BIMx's sign-in dialog. Tap on "About Graphisoft ID" in the bottom-left corner of this dialog to easily get to registration: https://id.graphisoft.com/user/register
  • "Pro" status is now displayed in BIMx's "..." more options menu next to your name if a BIMx Pro license is assigned to your Graphisoft account.
New licensing and additional features in BIMx Mobile
2023. September 27. - BIMx iOS 2023.5231, BIMx Android 5211, BIMx Windows 2023.5188, BIMx macOS 2023.5188, BIMx Web 2023.5260 on BIMx Model Transfer, Archicad 27
iOS and iPadOS:
Mobile, Web, Desktop
  • Interactive Labels
    Access BIM data easily on Layouts — new Labels toggle in Settings.
  • Dynamic skybox - even more realistic visuals: warmer colors at sunrise and sunset and night scene
Archicad 27:
  • Sun settings with date&time are saved into Hyper-models
  • New "Import issues from BIMx" button added to the BIMcloud message palette
Shadows and interactive labels in BIMx Web and Desktop
2023. September 27. - BIMx Windows 2023.5188, BIMx macOS 2023.5188, BIMx Web 2023.5260 on BIMx Model Transfer
New features on both web and desktop platforms:
Changes on Desktop:
BIMx Desktop has moved to online stores
2023. July 10. - BIMx Windows 2023.5041, BIMx macOS 2023.5042
BIMx Desktop Viewer is now available on Microsoft Store (Windows) and Apple App Store (macOS). Download the free application to get the next-generation desktop app's latest improvements, like the Measure tool and Shading options!
Archicad 27 will be the last main version that includes BIMx Desktop with an installer. Future BIMx updates will only be released for the store version.
Read more about the move in this article.
Accurate sun positioning by date and time
2023. June 12. - BIMx iOS 2023. 4966, BIMx Android 2023.4990
We're pleased to announce a new BIMx mobile feature that many of our users have requested. Sun positioning by date and time is available in the sun settings palette in the iOS and Android apps!
BIMx now displays sun movement on a path according to the project location and time zone – realistic shadows appear on the building and neighboring areas. Future BIMx Web and Desktop updates will also include this feature.
Read more in this article.
Measure and shading options in BIMx Web
2023. June 12. - BIMx Web 2023.4921 on BIMx Model Transfer
BIMx Web has been recently updated on BIMx Model Transfer, bringing the following new features in addition to stability improvements:
  • Smart Measure tool
    The long-awaited measure feature is available not only in the mobile apps but now in BIMx Web, too. Measure distances, angles, and areas both in 2D and 3D!
  • Display settings quick menu
    This quick menu in the bottom right-hand corner collects the settings relevant to the currently open 3D model. The field of view slider has been moved here from the general settings for easier access.
  • Shading options
    Additional render modes have been added to the default Realistic shading: Hidden line, Simple shading, Monochrome, and black and white.
Learn more about the new features in BIMx Web's online help. These improvements will also be available in the desktop version soon.
Smoother navigation and enhanced transparency in BIMx Android
2023. May 16. - BIMx Android 2023.4873
This update includes three noticeable changes in addition to the regular bug fixes and stability improvements.
  • The Android app has also received the enhanced transparency described in the iOS announcement below. Shadows are now visible on transparent surfaces like windows and curtain walls, resulting in a more realistic 3D representation – not only in the default Cast shadows render mode.
  • Smoother 3D navigation experience. Explore the virtual model with up to several times higher FPS (Frames Per Second). Increased performance is most noticeable in larger 3D models, mainly consisting of simple geometry elements like walls, slabs, beams, and columns. This improvement was first released on iOS in late November – read more details and see measurements in this article.
  • The required operating system version has been increased from Android 10 to Android 11. BIMx can be installed and updated from Play Store on devices running Android 11 or later.
Enhanced transparency in BIMx iOS
2023. May 15. - BIMx iOS 2023.4854
This update includes two noticeable changes in addition to the regular bug fixes.
  • Visual quality has been further improved with enhanced transparency. Shadows are now visible on transparent surfaces like windows and curtain walls, resulting in a more realistic 3D representation.
    See the right side of the comparison:
    Note: this enhancement is available in other shading options like Realistic and Simple shading. Future Web and Desktop updates will also receive it.
  • The required operating system version has been increased from iOS 13 to iOS 15. BIMx can be installed and updated from App Store on devices running iOS 15 or later.
Next-generation BIMx Web and Desktop apps
2023. Feb 15. - BIMx Web 2023.4654 on BIMx Model Transfer, BIMx Desktop 2022.4567
The next-generation BIMx Web app is already available on BIMx Model Transfer. BIMx Desktop has also been updated to the next-gen version. Get it on our revamped download site!
This powerful update includes improvements for architects, clients, and every BIMx user:
  • refined, modularized navigation system with new axis inverting toggles
  • increased performance with up to 15x faster loading times and optimized memory use
  • adjustable camera view cone and eye height
  • optimized UI with functional improvements
Read the Community article  for more details.
2022
BIMx Web update on BIMx Model Transfer
2022. Dec 05. - BIMx Web 2022.4389 on BIMx Model Transfer
This minor update includes a loading optimization for models exported from Archicad 22 and earlier. The conversion step is not needed anymore, resulting in more stable and faster loading of the Hyper-model index (list of publisher items).
Improved Performance in BIMx
2022. November 24. - BIMx Desktop 2022.4390 and BIMx iOS 2022.4506
  • Desktop  – get the latest version from our revamped download site.
    • Now running natively on Apple silicon, with improved 3D performance and loading speed. A separate installer is available.
    • Faster loading of the model index (list of publisher items). Increased loading speed is also available on Windows and Mac Intel devices, for models exported from earlier Archicad versions.
  • Mobile on iOS (Android coming soon) – install the update from Apple App Store.
For more information, please read this article.
Shadows in BIMx Android
2022. Sept 08. - Android app version 2022.4341
Shadow casting is available not only in the iOS but now in the Android application as well.
Read more about shadows here.
Shadows in BIMx iOS, More Functional BIMx Web and Desktop, Improved export
2022. July 14. - iOS app version 2022.4233, macOS and Windows app version 2022.4025, browser app version 2022.4026, Archicad 26
iOS and iPadOS
Considering your feedback, we implemented shadow casting as the default render mode, initially on iPhones and iPads
  • You can now adjust sun direction, height, and shadow intensity to achieve the perfect look.
  • Shadows are calculated on the fly: cut the 3D model and see the shadows adjust automatically.
  • Save favorite views with different sun positions and create stunning presentations!
This enhancement will soon be available on Android, and later on the web and desktop apps as well.
Web and Desktop
  • support of the new 3D format exported from Archicad 26 — faster 3D model opening
  • Ambient Occlusion, BIMx's on-the-fly rendering that can be switched on/off
  • new basic rendering that visually reflects project orientation - headlight method replaced to direct light, aligned to the project's Location Settings defined in Archicad
  • opening models with the Camera View Cone associated with the 3D model in Archicad - the ability to customize the 60° fixed View Cone used in previous app versions
The desktop application is part of the Archicad 26 package and is available to download on graphisoft.com.
The web application is available on BIMx Model Transfer and opens Hyper-models in a new browser tab instead of the smaller embedded frame.
Read this article for further details.
Improved BIMx publishing from Archicad 26:
BIMx Web on BIMcloud
2022. March 16. - BIMx Web 2021.3866 on BIMcloud 2022.1
After releasing BIMx Web on BIMcloud SaaS in January, it is now available in the on-premise version of BIMcloud, too.
Note: BIMcloud Basic does not include the BIMx Web app.
2022. January 07. - BIMx Web 2021.3865 on BIMcloud SaaS 2021.3
BIMx Web is available not only on BIMx Model Transfer but now on BIMcloud SaaS too.
Read more here.
2021
New BIMx for Android featuring a New 3D Engine
2021. July 07. - Android app version 2021.3557
A new version of the BIMx Android application has just been released featuring a brand new 3D Engine, new free functions, redesigned menu structure, and even more:
  • New rendering method for more realistic view with real-time lighting calculation
  • Improved startup speed - models open faster than ever before
  • Redesigned menu structure, so you find all settings in one place
  • New subscription plans are available inside the BIMx app / see more: BIMx FAQ and BIMx Licensing
The following previously PRO-only features are now available in the free version:
  • Smart Measure function
  • BIMx Presenter-mode  (Gallery-based)
  • Access BIMx hyper-model elements from outside of BIMx
New PRO in-app subscription feature set:
  • Open 3D models of any size, thanks to advanced Data Streaming technology
  • Save your favorite 2D and 3D project views
  • Create BIMx presentations using your favorite views
  • Print hard copies of any 2D and 3D view
  • Inter-app communication and integration with external databases via BIMx API
Renewed BIMx Desktop Viewer in the Archicad 25 package
2021. July 07. - macOS and Windows app version 2021.3441
The 1st update of the renewed desktop application is now part of the Archicad 25 package, and also available as a separate download from here. It includes several bugfixes, significant 3D performance improvements, and some smaller enhancements like 3D model loading progress indicator. See this article about BIMx changes arriving with Archicad 25.
2021. January 14. - macOS and Windows app version 2020.3231
The renewed BIMx Desktop Viewer is available to download on graphisoft.com from now. This is a macOS/Windows application that allows you to navigate in the virtual architectural project (saved in .bimx file format from Archicad) on desktop computers and notebooks. This new version lets architects and their clients access the full content of a Hyper-model, including 3D models, documentation and any embedded BIM data. It also supports touch screens, game controllers and SpaceMouse devices (https://3dconnexion.com/uk/spacemouse/) that helps anyone explore the building model and understand project deliverables.
NOTE:This in not an update for BIMx Desktop Viewer that already existed before but a brand new app so you have to install it in a separate folder if you want to keep both. This new app will be a default component of the Archicad 25 installation, until then you can install it manually.
2020
BIMx Lab for Android
2020. September 29. - Android App version 2020.3092 The first public release of BIMx Lab is already accessible in Google Play Store: https://play.google.com/store/apps/details?id=com.graphisoft.bimxlab BIMx Lab app delivers the next-generation 3D engine for BIMx, GRAPHISOFT's mobile BIM communication tool. This technology preview app aims to eliminate the BIM model size limit, prevalent on mobile devices, and collect user feedback for fine-tuning the technology for all BIMx apps. You can access productivity functions in BIMx Lab that are available otherwise only in the paid BIMx Pro version. All of those are free in BIMx Lab for a while, as we are planning to maintain BIMx and BIMx Lab apps side by side until BIMx Lab will deliver at least the same stability and quality. Then the new BIMx Lab engine will be merged into BIMx. Please start using it and send your comments/suggestions to [email protected]!
New BIMx for iOS featuring a New 3D Engine
2020. July 08. - iOS App version 2020.1087 A new version of the BIMx iOS application has just been released today featuring a brand new 3D Engine, Improved speed, redesigned menu structure and more:
  • Hyper-models with unlimited 3D model size, thanks to advanced data streaming technology
  • Photo-realistic view with real-time lighting calculation for better shadows
  • In-app purchase option to replace the stand-alone BIMx Pro application / more info
  • New subscription plans are available inside the BIMx app / more info
2019
BIMx Web Viewer renewed
2019. September 29. The renewed BIMx Web Viewer (Help) allows clients and other project stakeholders to view BIMx Hyper-models directly in their browsers, enjoying various intuitive, game-like navigation options.
  • It is an integrated part of the free BIMx Model Transfer service and works on any mobile and desktop devices including iPhones, Android phones, Windows PCs, Apple Macs or convertible computers like Microsoft Surface.
  • BIMx Web Viewer is supported on most major browsers (System Requirements) (though it most thoroughly tested on Chrome, Edge and Safari) and it does not require any browser-plugin to download or any software to install.
  • BIMx Web Viewer offers various intuitive, game-like navigation options. Viewers can navigate in the 3D model by using their keyboard, touchpad or mouse and their touch screen. Enable the gamer mode and control the movement using an Xbox compatible video game controller.
  • Active ARCHICAD SSA (Software Service Agreement) holders can easily embed BIMx Web Viewer in their own website to present their company’s portfolio to clients and prospects in a unique way.
2018
BIMx 2018 Q2 Update –  Presentations with BIMx mobile
iOS App version 2018.2.1562 and Android App version 2018.2.1584
  • The new Presenter feature  allows architects and clients to experience building designs in a more immersive and organized way. With it architects can hand-pick the most expressive 3D model views or drawings and organize them into an animated presentation on their smart-phones and tablets.
  • In addition to one-on-one project discussions, BIMx Presenter can be the highlight of any presentation when the smart-phone or tablet is connected to a TV screen or projector. Switch to continuous loop to automatically run the presentation in the background during meetings, exhibitions and conferences.
BIMx Model Transfer service - BIMx Web Viewer released
2018.04.19. - The browser-based version of BIMx  is now available, making ARCHICAD content navigable as an additional service of the BIMx Model Transfer site. The BIMx Web Viewer lets users and their clients access the full content of a Hyper-model, including 3D models, documentation and any BIM data without having to install an application or browser plug-in. Users can navigate directly in their browser window on both PC and Mac. Active SSA (Software Service Agreement) holders can easily embed BIMx Web Viewer in their own website to present their company’s portfolio to clients and prospects in a unique way.
2017
BIMx 2017 Fall Update - BIMx Tips and Hyperlinks in Schedule views now available
iOS App version 2017.2.1250 and Android App version 2017.2.1271
  • BIMx Tips
    • Presents optional, short BIMx usage tips and tricks within BIMx apps a few times in a month, when the app starts. Also, provides a weblink to the related GRAPHISOFT Help Center article where the tip is explained in details. Available in ENG, GER, RUS, KOR and JPN languages. Both on iOS and Android.
  • Hyperlinks in Schedule views
    • Hyperlinks will be generated automatically between 3D model elements and their representation in Interactive Schedule drawings placed on a Layout within the same Hyper-model. When you tap on the schedule item an interactive popup helps you to find and select the related element(s) in the connected 3D model. In this way, not only the model derived 2D drawings but also the schedules will be hyperlinked with the 3D model.
BIMx 2017 Q2 Update –  Architects can now display their credits in BIMx mobile
iOS App version 2017.2.951 and Android App version 2017.2.1002
  • Combining ARCHICAD 21 new Publisher Set Properties and BIMx latest release, Architects can now display their credits (website URL and Logo) directly in the BIMx hyper-model
  • ARCHICAD 21 publishing improvements
    • The BIMx transfer site quotas (Public and Private) are now available from the Publisher Set Properties window, allowing the users to have an overview of the storage space already used
    • Now you can select multiple Schedules for the Info Set, in the Publisher Set Properties window
  • BIMx enhancements
    • Welcome screen (new users only)
    • New features overview (after application update)
BIMx 2017 Q1 Update part II -  Push notification from BIMx Transfer Site
iOS App version 2017.1.787 and Android App version 2017.1.827
  • Push notification is now supported in BIMx: get a short text message when a Hyper-model obtained from BIMx Model Transfer service has been updated and is ready for download.
  • Enhanced download protocol has been introduced, making it significantly faster to download a Hyper-model or an update from the BIMx Model Transfer service.
  • The issue on devices with iOS 10.3 version, which causes BIMx files to disappear if the Hyper-model name contains accented letters (éáöüí etc.), has been fixed.
BIMx 2017 Q1 Update part I -  Share your project on social networks in BIMx
iOS App version 2017.1.662 and Android App version 2017.1.682
  • Google Drive is now supported in BIMx to transfer Hyper-models on all desktop and mobile operating systems (including Microsoft Windows, Apple macOS and iOS as well as Google Android devices).
  • Apple AirDrop is also supported in BIMx, making it easy to transfer Hyper-models among any iOS or macOS devices.
  • New options for sharing Hyper-model with friends and business partners:
    • as an interactive, panoramic 360 Photo on Facebook
    • as a Tweet or LinkedIn update, with embedded camera view, directly from the BIMx model
    • or using any other sharing methods (email, iMessage, Messenger, Viber, Yammer, etc.) for which you have installed the appropriate app.
2016
BIMx 2016 Fall Update - BIMx is now supporting the most popular Virtual Reality device
iOS App version 2016.3.530
  • Google Cardboard Support
    • Look around at pre-defined positions through your Gallery items or favorites
    • Walk freely within your 3D model with custom speed options
  • BIMx now supports split view, you can work simultaneously on two apps at the same time on your iPad
    • Beneficial if you are using URL-based data exchange between BIMx and a 3rd party app
  • BIMx allows you to create hyperlinks with more elements included into the same URL
Android App version 2016.3.561
BIMx 2016 Q2 Update - Free access to 2D content of any Hyper-model
iOS App version 2016.2.397
Android App version 2016.2.432
  • New design
  • Improved performance and higher availability
BIMx Product Site
  • New site fully dedicated to BIMx, access it from here
BIMx 2016 Q1 Update - Hyper-model sharing becomes platform independent
iOS App version 2016.1.227
Android App version 2016.13.255
  • The sharing link can be forwarded anytime later to anyone, thanks to the BIMx Model Transfer site storing the model sharing links together with the Hyper-models.
2015
BIMx 2015 Q4 Update - Access model elements in BIMx via hyperlinks
iOS App version 15.4.158
BIMx 2015 Q3 Update - BIMcloud connection taken to the next level
iOS App version 15.3.58
  • Join a BIMcloud Teamwork project from BIMx to enable BIMx PRO functions
  • Attach Camera Photos to the BIMcloud Teamwork messages
  • Create schedule sheets with interactive web page and email address hyperlinks
Android App version 15.3.102
BIMx 2015 Q2 Update - Direct Cloud Storage Access
iOS App version 4.0.2809 The latest BIMx update released together with ARCHICAD 19 presents four new features on iOS devices:
Android App version 3.5.3510 This new update introduces BIMcloud messaging from your Android device as well as compatibility developments to support BIMx files exported from ARCHICAD 19.
BIMx 2015 Q1 Update - Simplified licensing with BIMx PRO
iOS App version 3.6.353 BIMx Docs has been renamed to BIMx PRO. This change doesn't affect the existing features in any way and doesn't contain any addition to what BIMx Docs had. With the update BIMx Docs becomes BIMx PRO. Simplified Licensing
GRAPHISOFT simplifies BIMx licensing options for iOS devices. From this point two licensing options are available:
  • purchasing a license for all models on one device (suitable for architects)
  • sharing a license for one model with other parties for an unlimited amount of time (architects can share the model with all AEC stakeholders)
 Just like before, BIMx is the free app offering In-App purchases and BIMx PRO is the paid app containing all extras by default. Read more about the new simplified licensing options in our BIMx Licensing article.
Faster Model Download
This update brings a significant improvement to model download speed. Larger file downloads from the BIMx Model Transfer cloud service remain stable even when the app is in the background.
