incorrect View form Opening Side
What might be causing an incorrect View from Opening Side in my schedules?
What is showing could be the inside view but that is not one of the Fields. ?
The doors are placed correctly, and they do look correct in Elevation and 3D views. There is a wall in front of the wall with the garage door in it. I have an Simple Door Opening hole in the brick wall that is in front of the doors. But why does it work fine for one and not the other ??
All of the other things I have scheduled for View from Opening Side work look fine. Tried to change and edit the door, nothing works. ??
0 REPLIES 0
Learn and get certified!
