Srinivas
3D AutoCAD Export Problem - ArchiCAD 11
I have a problem exporting an ArchiCAD V 11 model into AutoCAD 3D. Attached is the image that I saved from ArchiCAD V 11.
I am working with ArchiCAD USA V 11 - Build 1033.
I am using the same DWG translator settings in both the versions, but still with no luck.
Thanks in advance.
- Srinivas
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
49 Replies 49
Srinivas
Here is the image of the same project that I saved from ArchiCAD v 10 before migrating the project to Version 11.
ArchiCAD Service
Mac, Windows 11
Thomas Holm
I don't know if it helps. but you're 3 hotfixes behind. Help >Check for updates.
Srinivas
thanks for the response, I was not aware that I am 3 hotfixes behind intentinally skipped one of the hotfix because it had problems, I will download the latest one and get back
ArchiCAD Service
Mac, Windows 11
Srinivas
Checked with the latest build, but with no luck.
Did any one had this problem?
Thanks
ArchiCAD Service
Mac, Windows 11
Thomas Holm
I haven't seen it. I think you should report it as a bug through your reseller. If possible, supply both your .pln, any custom materials, your saved translator and the dwg output you get.
Erika Epstein
Have you tried exporting it with a 3D translator such as IFC?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Srinivas
No I didn't tried it yet, but can AutoCAD directly open IFC or does it need an addon to open it?
Thanks.
ArchiCAD Service
Mac, Windows 11
No, no IFC with vanilla AutoCad, but AutoCad Architecture (former Architectural Desktop) has it.
Anssi
Erika Epstein
Srinivas,
What are you trying to accomplish?
The entire model to be used in autocad? autocad is 2D
2Ddrawings?
You might also be able to export the model as a library part, but even if that works is this going to be helpful?
Autocad is 2D, revit is 3D and the latter uses IFC.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
