Djordje
ACC issue with Archicad DWGs
Hi all!
Elsewhere, I wrote about the successful publishing to Autodesk Construction Cloud. Yes, it all publishes, BUT!
The published DWGs cannot be viewed on ACC.
Instead of the whole DWG, only the bottom left corner is seen.
Did anyone else have the same issue? I have checked with some of the European users, and they never had this issue. Could this be a location/used cloud server issue? Our excellent local reseller/support @Medialogic Support is on the case, but they are as baffled as we are, and so is the local Autodesk support.
We have tried opening the DWGs in Autodesk DWGTrueView and converting it there, opening it in AutoCAD, saving it from there, and nothing changes.
Ideas? Solutions?
Operating system used: Windows 10
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
12 Replies 12
Does it make any difference if the DWG is saved as Model Space or Paper Space?
Matyas Csapo
Does the same happen with the Autodesk Online Viewer? https://viewer.autodesk.com/
Software Engineer
Aaron Bourgoin
We're experiencing a similar issue.
ACC uses geolocated DWGs to navigate the model. We can't produce Layouts in DWG that link to the IFC we export.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Djordje
Hi @Matyas Csapo
Yes, the same issue. See below.
Djordje
HP Omen
Djordje
Correct.
We did not try publishing to ModelSpace, as there is no point: the GeoLocation info is lost in the Layout.
BTW, the "geolocation" that we have seen in all the models coming from Revit, RVT or IFC, is placing the model at the actual coordinates. As you know. That is not geolocating...
... it is really frustrating when whole systems bend to the inadequacies of the products of the big boys...
... but hey, our origin/Survey Point works in IFC. It would be good if it worked in Layout, too.
Djordje
HP Omen
Djordje
Just now tweaked the Translator to MSpace, and some other details (getting rid of the penweights, as they usually create a messy file) aaaaaaand...
it works in Autodesk Viewer. "Only" issue is that all the images placed on the layout (all the logos of the stakeholders) are black. Lemme check that...
also works in ACC. "Only issue is that all the images placed on the layout (on the Master) are missing, although they are loaded in the same folder as the DWG
So, we can mark this as a "solution", maybe?
Djordje
HP Omen
Aaron Bourgoin
Geolocation of Layouts published as sheets that are linked to an IFC is the most important part of Archicad / ACC integration. A make or break issue.
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
feczo77
Hi Djordje, I have the same problem as in the post. Can you write what you changed in the translator after which it worked?
Thanks,
Gábor Feczkó
Djordje
Hi guys
Duplicate message, so editing this one..
Not holding my breath, if the geolocation is the issue... so the promoted ACC connectivity is NOT, repeat NOT complete, despite the claims, until this is sorted. The world works on drawings, not on models. Horrible truth.
Djordje
HP Omen
