2008-10-19 12:09 AM
2008-10-22 10:03 PM
2008-10-28 08:50 PM
2008-10-29 03:08 AM
cgrimley wrote:not tried yet, but i hope it can do it. because we've installed a hoxfix (i guess something inside would let us view the model but can not edit if we haven't installed the MEP )
Karl (or anyone else who has done some testing)
Have you done any testing to where a user without the mep modeler opens a model that has those mep objects in it?
Can they see the objects, just not edit them?
Thanks
2008-10-29 04:44 AM
cgrimley wrote:Everything is present for someone with a regular AC license. The objects 'smarten up' when the file is re-opened with an MEP license.
Thanks
2008-10-29 04:51 AM
If a project created in an MEP environment is reopened using ArchiCADSeems reasonable: stuff is locked when viewed with a regular AC license to prevent accidental editing (but editing is still possible). All of the 'smarts' return when opened with an MEP license.
only (without MEP Modeler), the MEP objects are available, although
locked for editing. If you wish to edit or move these elements, you must
first unlock them individually (Edit > Locking > Unlock). Their MEP
connection information - once you have edited them in a non-MEP
Modeler environment - is lost, and they behave as plain GDL objects in
ArchiCAD.
If an ArchiCAD project is opened (using File > Open) in an MEP Modeler
environment, then the GDL objects that are MEP-compatible will be
automatically “smartened up” and their connection parameters can be used to include these objects as part of an MEP route.
2008-10-29 03:14 PM
2008-11-18 11:15 PM
2008-11-19 12:18 AM
garbage75 wrote:The MEP modeler is a combination of add-on, library, work environment and template for ArchiCAD 12. It is not a separate application.
hi at all..
first of all sorry for my bad english.. I'm an italian users... so... I'm just reading about MEP.. and I'd only like to know some thing..
first af all. MEP is a modeler (internal or external) like any other cad or poligonal or surface application like cinema 4d or rhinoceros or any other product? or is a kind of AC plugin like archiforma?
when could it be ready for AC 12?
2008-11-19 01:37 PM
garbage75 wrote:Watch the ten or so videos on the following web page and you will have a pretty good idea of what it is capable of and how it does it:
hi at all..
thanks a lot
garbage
2008-11-19 07:30 PM
laszlonagy wrote:That is very impressive.
