We value your input!
Archicad 7 Zone analytical area calculation??
i m looking for a feature in archicad 22 that was available in archicad 7, where you could calculate the area of a zone but also break it down to simpler shapes dimensioning each one and producing a list with every calculation or each shape, with a sum at the end.
Here is a photo from our old computer at the office, sorry for the banding.
papsphilip wrote:
Bruno wrote:
No it's an ArchiCad Feature for a while, it's an Area List, you'll find it under "Documentation/List Extras/Area List" (see attached Image).
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).
Thank you for the reply! It would be really helpful if you could explain a bit more how can i produce this area analysis drawing with the corresponding calculations in Archicad 22? Can you provide a bit more specific instruction because i've been looking everywhere but i cant find it
The detail use of this extension is describe in ArchiCad Reference Guide in the Supplement part.
First of all they say that Functions describe in that section are not available in all localized versions, so you may have a version without this feature.
Regards
Bruno Hepp
10 REPLIES 10
That must have been a 3rd party add-on.
It certainly isn't anything I have seen built into Archicad (since version 6.5).
yes i think you are right, maybe ArchiSuite by Cigraph has this feature
What's new in 22 : Area List appears in the Navigator, there's no preconfigure Area List so you have to create your own, but you can create as much as you want (see attached Image).[attachment=0]Liste de surfaces.pdf
I am not very familiar with localization-specific ARCHICAD features, but it seems to me that this may be something that was/is? available in German language versions of ARCHICAD.
If anyone knows, please correct me.
"List Areas.apx" there is also in Greece & German vers. and works only on them - not INT .
The same I am looking for !
regards
Vasilis
regards
Vasilis
My ArchiCad version is a French one, the "List Areas.apx" works in it. It comes with ArchiCad installation.
Image attached on my previous post
regards
Bruno Hepp
Regards
Bruno Hepp
agroni
It is also available in the Austrian version...
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
