2004-09-28 05:50 PM - last edited 2 weeks ago by Molinda Prey
2004-09-28 05:58 PM
another Moderator
2004-09-28 06:19 PM
ejrolon wrote:Is "publishing" the file something new or a better way to do it? I have just been saving it as a .dwg with version 8 and it seems to work fine with ADT 3.3.
You will have to "publish" the file to dwg. So, Yes...
2004-09-28 07:05 PM
Steve wrote:Steve,
2004-09-28 07:26 PM
2004-09-29 01:17 PM
2004-10-01 06:58 AM
Steve wrote:Not in my experience. This would be useful - practically, you save the WHOLE content into a DWG, and then the Layer combinations get translated into Layer status in AutoCAD.
Are you able to read the ArchiCAD layer combinations as Layer Keys in AutoCAD? How does it work with layer combinations?
2004-10-01 03:15 PM
Djordje wrote:Actually each PM layout becomes a DWG and the views within the layout become pspace viewports. That means that each view is a different drawing within the layout dwg (switch to model space in Autocad to see the different drawings) that has only the lines that match AC's layer sets. In paper space all the viewports match AC's view settings regarding scale and lineweights.
The way it works now is that eash of the ArchiCAD views traslates to one DWG that has the layers necessary, with the display options as defined in the view settings. ,
another Moderator
