One thing you need to do in the Criteria panel:
You should put all the "Composite" Criterion Lines between parentheses. Place the starting parenthesis before the first "Composite" Criterion", and place the end parenthesis after the last "Composite" Criterion". Then only those element will be scheduled that you intended.
With the generated Schedule, you will see the options panel on the left. At the top, check the "Merge Uniform Items" checkbox, that should achieve the results you are trying to get (if I understood your request right).
