Converting 3ds files to dwg or dxf
I have some 3d furniture files from the manufacturer but they are in 3ds form. I think to get them into ARCHICAD I need to convert them to dwg or dxf format. Does anyone know how I can do this?
11 REPLIES 11
There is a 3D Studio import Add-On you can download and add to ArchiCAD.
Use the Help\ArchiCAD 15 Downloads menu command to get to the download site.
Thanks very much - this worked.
Hi... I also want to import 3ds in archicad 15, but when I go to help / Archicad 15 Downloads, it says that : cannot find html file or viewer . Can u please specify the link where to find that plug-in? I have educational version, I hope that's not a problem.
Thank you.
TMA_80
when you click on help/archicad15 download, does it open your internet navigator ?
AC12_27 |Win11_64bit|
nope... this is what I get when I open the "Archicad 15 Downloads" option from the "help" tab ... the text is not clear, but it says exactly: cannot find html file or viewer
TMA_80
You could look in the graphisoft directory on your HDD, for the folder named internet links ( or something similar ) you should find there a shortcuts for the addon download link....
thanks... i found it .
the link was http://www.graphisoft.com/support/archicad/downloads/ac15/INT.html and the file was called "3d studio in".
i did the steps but i get that not all add ons will work perfectly and i couldnt convert the 3ds file to archicad can someone let me send him the 3ds file and make it pln for me ?
Send me the file and I will see what I can do. I may or may not be able to do it as the file may contain data that does not make it possible.
Please state your ArchiCAD version.
Send the email to
gsforumadmin@graphisoft.hu
