I have some 3d furniture files from the manufacturer but they are in 3ds form. I think to get them into ARCHICAD I need to convert them to dwg or dxf format. Does anyone know how I can do this?
Hi... I also want to import 3ds in archicad 15, but when I go to help / Archicad 15 Downloads, it says that : cannot find html file or viewer . Can u please specify the link where to find that plug-in? I have educational version, I hope that's not a problem.
Thank you.
nope... this is what I get when I open the "Archicad 15 Downloads" option from the "help" tab ... the text is not clear, but it says exactly: cannot find html file or viewer
You could look in the graphisoft directory on your HDD, for the folder named internet links ( or something similar ) you should find there a shortcuts for the addon download link....
i did the steps but i get that not all add ons will work perfectly and i couldnt convert the 3ds file to archicad can someone let me send him the 3ds file and make it pln for me ?
Send me the file and I will see what I can do. I may or may not be able to do it as the file may contain data that does not make it possible.
Please state your ArchiCAD version.
