Zdenko
DWG custom beams/walls/columns Import
will be receiving some DWG files and wanted to know how do i import customized beams/walls/columns from another file? thinking of something like blocks from autocad or something similar.
Operating system used: Mac Intel-based Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
2 Replies 2
Patrick M
Ace
is it 3d dwg? you can bring a 3d dwg in using the file > interoperability > merge function. that will typically bring in the dwg as a single object; but you can convert that to a morph and  break apart into separate componenets.
If it is a 2d DWG, there are several ways to bring it in. My go to is to drag/drop, then explode into lines and fills. But you can also open (for 2d or 3d) in a separate instance of archicad adn copy what you need or use the x-ref manager. These methods usually add a lot of attributes and layers to your file, which is a PITA in my opinion.
Zdenko
thank you for quick response on a friday! did not realize i can have multiple instances of ac was allowed! hot dang! not sure just what i will be getting but not a fan of exploding and dealing with PITA attributes...
Sequoia 15.1.1
