2024-05-10 09:16 PM - last edited on 2024-05-10 11:20 PM by Karl Ottenstein
will be receiving some DWG files and wanted to know how do i import customized beams/walls/columns from another file? thinking of something like blocks from autocad or something similar.
Operating system used: Mac Intel-based Sonoma 14.4.1
2024-05-10 09:46 PM
is it 3d dwg? you can bring a 3d dwg in using the file > interoperability > merge function. that will typically bring in the dwg as a single object; but you can convert that to a morph and break apart into separate componenets.
If it is a 2d DWG, there are several ways to bring it in. My go to is to drag/drop, then explode into lines and fills. But you can also open (for 2d or 3d) in a separate instance of archicad adn copy what you need or use the x-ref manager. These methods usually add a lot of attributes and layers to your file, which is a PITA in my opinion.
2024-05-10 09:50 PM
thank you for quick response on a friday! did not realize i can have multiple instances of ac was allowed! hot dang! not sure just what i will be getting but not a fan of exploding and dealing with PITA attributes...
