2024-02-08 06:22 PM
So.... Is it possible? Or do I have to do it through another software, like blender?
.Kamelite
Solved! Go to Solution.
2024-02-08 07:11 PM
Yes in ArchiCAD 27(which your signature lists) it is once again possible.
As long as you are viewing in 3D, SaveAs should have an FBX extension available to select
2024-02-08 07:11 PM
3 weeks ago
Good afternoon!
1. Try installing the ArchiCAD add-on for Twinmotion and you will be able to import FBX files even from version 19.
2. 27th version has everything even without additions. I have attached screenshots below.
