Export windows without a wall?
ananas
Hi everyone,
Is there a way to export windows without the wall in Archicad? It would be really helpful, as I'm rendering a model with various window types.
I'm currently using Archicad 26, where Design Options aren’t available yet.
Operating system used: Windows 11 Pro 23H2
vistasp
Would this work for you?
The wall is zero height and the material is air.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
7 REPLIES 7
Export to where?
I doubt it though as in Archicad windows belong to the wall - no wall, no window.
Guru
You might be able to if you export as a SketchUp file as you can toggle which elements are exported, including windows. Have not tried before, and the windows may or may not be associated the the wall.
Hi Lingwisyer,
No that doesn't work as when you toggle walls off it automatically toggles windows off.
ArchiCad 3.43 to 28
MacOS Monterey
Guru
Suspected that might have been the case...
vistasp
= v i s t a s p =
bT Square Peg
to D5 render.
Yes, i take that workaround 🙂
Thank you
Setup info provided by author
