2024-10-23
05:46 PM
2024-12-17
08:44 PM
Hi everyone,
Is there a way to export windows without the wall in Archicad? It would be really helpful, as I'm rendering a model with various window types.
I'm currently using Archicad 26, where Design Options aren’t available yet.
Operating system used: Windows 11 Pro 23H2
Solved! Go to Solution.
2024-10-24 11:06 AM
Would this work for you?
The wall is zero height and the material is air.
2024-10-24 03:39 AM
Export to where?
I doubt it though as in Archicad windows belong to the wall - no wall, no window.
2024-10-24 04:00 AM
You might be able to if you export as a SketchUp file as you can toggle which elements are exported, including windows. Have not tried before, and the windows may or may not be associated the the wall.
2024-10-24 09:29 AM
Hi Lingwisyer,
No that doesn't work as when you toggle walls off it automatically toggles windows off.
2024-10-24 09:57 AM
Suspected that might have been the case...
2024-10-24 11:06 AM
2024-10-24 11:16 AM
to D5 render.
2024-10-24 11:17 AM
Yes, i take that workaround 🙂
Thank you
