ananas
Export windows without a wall?
Hi everyone,
Is there a way to export windows without the wall in Archicad? It would be really helpful, as I'm rendering a model with various window types.
I'm currently using Archicad 26, where Design Options aren’t available yet.
Operating system used: Windows 11 Pro 23H2
1 Solution
vistasp
Mentor
Would this work for you?
The wall is zero height and the material is air.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Go to post
7 Replies 7
Export to where?
I doubt it though as in Archicad windows belong to the wall - no wall, no window.
Lingwisyer
Guru
You might be able to if you export as a SketchUp file as you can toggle which elements are exported, including windows. Have not tried before, and the windows may or may not be associated the the wall.
BrunoH
Hi Lingwisyer,
No that doesn't work as when you toggle walls off it automatically toggles windows off.
ArchiCad 3.43 to 28
MacOS Monterey
Lingwisyer
Guru
Suspected that might have been the case...
vistasp
Mentor
= v i s t a s p =
bT Square Peg
ananas
to D5 render.
ananas
Yes, i take that workaround 🙂
Thank you
