Wednesday - last edited Wednesday
Hi everyone,
Is there a way to export windows without the wall in Archicad? It would be really helpful, as I'm rendering a model with various window types.
I'm currently using Archicad 26, where Design Options aren’t available yet.
Operating system used: Windows 11 Pro 23H2
Solved! Go to Solution.
Thursday
Would this work for you?
The wall is zero height and the material is air.
Thursday
Export to where?
I doubt it though as in Archicad windows belong to the wall - no wall, no window.
Thursday
You might be able to if you export as a SketchUp file as you can toggle which elements are exported, including windows. Have not tried before, and the windows may or may not be associated the the wall.
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
Thursday
Hi Lingwisyer,
No that doesn't work as when you toggle walls off it automatically toggles windows off.
Thursday
Suspected that might have been the case...
Thursday
Thursday
to D5 render.
Thursday
Yes, i take that workaround 🙂
Thank you
