I downloaded and executed "MEP Modeler Downloads for ArchiCAD 16" > "INT for Windows" and installed it at C:\Program Files\GRAPHISOFT\ArchiCAD 16\Add-Ons.
I was though not sure about which hotfix to apply this time, since I had used the "Check for Updates" command in ArchiCAD the previous time, which is not available now since ArchiCAD doesn't start. Therefore, I examined the most recent one for AC16, "Hotfix 5 - build 4010".
While running the hotfix, I got the message "The installed ArchiCAD found at location C:\Program Files\GRAPHISOFT\ArchiCAD 16 has already been updated. Running ArchiCAD again results in an interrupted start and a "Graphisoft Bug Reporter" window.
Then I tried an earlier one, "Hotfix 4 - build 3827" which results in the message "The installed ArchiCAD found at location C:\Program Files\GRAPHISOFT\ArchiCAD 16 is newer than this Hotfix".
Any further advice?
