Since the option for the fields is boolean (true/false), I doubt it's possible to do through the Scheduler. Once you have it placed once, the only option is to turn it back off.
You could probably modify your objects to have an internal parameter that duplicated the ID field. Yeah, I know, it's not even remotely feasible to modify every door & window you use, but it is possible.
You could also cheat and place the view twice in Plotmaker, with one of them cropped to just show the ID column.
Tom Waltz
