2020-04-22 03:47 AM
2020-04-23 11:03 PM
2020-04-23 11:28 PM
LaszloNagy wrote:The intended effect is that of Excel, Preferences>View, Window Options, “Show zero values” unchecked. Cells with value equal to zero show blank, as if empty. Sometimes you don't want to go that way, because in some cells showing zero does matter, or at least it tells you that nobody overwrote that formula etc., so I usually use IF formulas giving a space (" ") for formula result = zero TRUE, or showing the result for FALSE. I tried that in AC but I am told that an expression cannot have a text result (" ") if TRUE and a number or other calculation value if FALSE, they both need to be of the same type, or that is what I understood.
Could you show an example of the desired result?
I reckon you will have to use Expression-defined Properties to achieve it, but let is see those screenshots first.
2020-04-24 02:07 AM
2020-04-24 05:53 AM
2020-04-25 01:33 PM
2020-04-26 07:17 PM
2020-04-27 02:25 AM
