Project Reviewer
Does anyone use project reviewer effectively and care to comment? I would like to work more remotely with my office.
Thanks
12 REPLIES 12
ricki-fritz
Based on the multitude of replies you've received, I'm guessing.... not many??? ;o)
I have a similar query - testing how redlined DWF files from the Reviewer can be imported back to ArchiCAD for amendments.
The manual says:
"Redlined DWF files can be incorporated in the ArchiCAD file by using Project Mark-Up. See the next section for details. "
The next section says:
"Provided that the published files are saved in DWF format, non-ArchiCAD users can add further redlining with Project Reviewer. Redlined DWF format files can be sent to you by the reviewer. You can import these DWF files as a new Mark-Up Entry. "
To import the DWF the manual says:
"You can create new entries by clicking the red folder button ...... In addition, instead of creating an entry from scratch, you can choose to import a DWF file created in Project Reviewer for redlining the published Project."
I've done these steps and been able to select the redlined DWF file, but no elements appear at all....
Any help appreciated...
Ricki
Graphisoft Certified ArchiCAD BIM Manager
ArchiCAD 29
Windows 11
Well..I just recently discovered this and it giving me error messages....I would really like to get this to work....
would really love some feed back from Graphisoft on this.....please....
you should elaborate a bit more on what the problem is, what the error message is, what you are trying to do, etc. Please also include system and ArchiCAD version information.
1st error message....this happens when reviewerJ2.jar.....is activated
here is the message I get when I use the javadetect.......
I've just run into a problem on the client's browser when accessing a project site:
Graphisoft Reviewer now detects your Java Virtual Machine, please wait...
In the status bar it says:
Applet com.graphisoft.javadetect.JavaDetectSilent started...
The JavaConsole says:
Java(TM) Plug-in: Version 1.4.2_04
Using JRE version 1.4.2_04 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\ferenc
Proxy Configuration: No proxy
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
OS name : Windows XP
OS architecture : x86
OS version : 5.1
Java vendor : Sun Microsystems Inc.
Java version : 1.4.2_04
OS version : 5.1
OS version : 5.1
Just for testing, I set the Internet Options/Security to Low,
and Reinstalled the Java VM from the ArchiCAD 9 USA CD
It is a Windows XP oon a Pentium IV machine.
The site works fine on my HP laptop and powerbook using either IE or FireFox browsers
There is not much more debugging I can think of.
It would be nice if they could do redlining online.
ok.....I got it to work .... but there are some bugs....but I think this can be a great tool.....for a couple of reasons....one of which...it can be set in your website and while your at a meeting with a client making notes...your coworks back at the office can be picking up changes...kinda sweet .... I think...
good for you.
It's a useful tool, if your client's browser doesn't hang in the JavaDetect phase. So you kind'a need to be careful and test it at the client first.
JavaDetectSilent -as the name implies:) doesn't tell you too much about what's his problem or how that can be addressed.
