a month ago
Hi!
Is it possible to reduce IFC files and if yes, how?
My Archicad file is over 1GB big and its IFC export is 100MB big.
If I understand correclty, IFC file is already reduced as much as possible? Or are there any ways to make it even smaller without zipping it?
I would like to reduce tis size by half 🙂
Operating system used: Windows 11 Pro 23H2
Solved! Go to Solution.
a month ago
@ananas wrote:
Do you have any advice on how to reduce the amount of information exported.
It's important to export the model according to the recipient's requirements. This means that you shouldn't export the model 'as is', but according to the BIM Execution Plan (BEP), or at least according to the model requirements for a specific discipline. Correct model content and data is much more important than the size of the model in megabytes.
Export only the data that you need. For example:
If you're exporting the model for structural engineers, keep only the structural elements (no furniture, no HVAC, no plumbing, etc.), use only a Partial Structure Display (Core of Load-Bearing Elements Only), so you wouldn't export all the wall composites. If structural engineers don't need classifications and properties, omit them too.
Experiment with different IFC translators, find the one that suits your needs, then configure and refine it.
a month ago
There was a nifty tool called Solibri IFC Optimizer, but it seems to have been discontinued.
However, if you want to drastically reduce IFC file size, you need to reduce the amount of information exported.
a month ago
Thank you!
When I check the IFC file after export, it seems like it only exports the information that are edited and keeps out all that we did not use.
a month ago
Just a comment - an IFC-file beeing 100mb, coming from a 1gb file, that is what I would consider a small file. I've had way bigger IFC's from smaller files than that.
Why the need to cramp the size?
.Kamelite
a month ago
3 weeks ago
I noticed that biig libraries and publisher set adds alot to the file size. So in my case I was expecting a muuch smaler IFC file (that does not export anything else, but geometry).
I need to reduce the size in order to import IFC file into a software that has IFC size limitation.
I did not succeed though, I think my IFC file is the smallest possible already 😄
3 weeks ago - last edited 3 weeks ago
I think the best way we could help you is if you posted all the export settings in all IFC Translation Dialog as screenshots.
I would particularly be interested in the setting of the following subdialogs:
3 weeks ago
Have you tested any other IFC-compressoer siftware, like this? https://yushen-liu.github.io/IFCCompressor/index_software.html
I have not tested it myself...
.Kamelite
3 weeks ago
- last edited
3 weeks ago
Hi!
I did notice the OPENINGS cause an issue! Size is not an issue at all!
There is an exklamation mark, if I export the openings:
I don´t know why thought. Any suggestion on how could I analyse the issue?
I deleted all the openings from the file and the error remains.
If i turn off openings in IFC translation settings, there is no explamation mark and my IFC file can be used in another software (no matter the size).
I do see this exklamation mark with different Archicad projects, also in the empty fresh one from Archicad template.
