‎2014-09-19 09:00 PM
‎2014-09-19 09:09 PM
another Moderator
‎2014-09-19 09:33 PM
ejrolon wrote:
Add a Custom Parameter to the Schedule and change the header name to Material.
‎2014-09-22 03:42 AM
‎2014-09-22 03:30 PM
Barry wrote:
Don't your window objects have parameters for the materials?
You can use those in your schedule by using the "ADD" button in the scheme settings to "Add Object Parameters" then searching for the material parameter in the window objects.
Then edit the column header as already mentioned if required.
‎2014-09-23 04:37 AM
‎2014-09-23 04:42 AM
‎2014-09-23 06:01 PM
