funky dimensions in schedule
jkershaw
ok, folks, here's a new one for you:
In my window schedule, the dimensions are showing up as shown in the attached image. 1'-12"? 3'-12"? I've never seen ArchiCAD do that before.
The widths appear correctly in the window object. I've checked my dimension settings. The height displays correctly. I'm at a loss for how to correct this.
Any thoughts would be appreciated.
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
12 REPLIES 12
vfrontiers
This was actually an issue prior to AC 21....
The OLD workaround was to keep typing 2'-0" right in the schedule and eventually it would HEAL... but with the AC21 upgrades, this no longer works either!
Not looking good to the contractors!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
zoli79
I don't know if your issue is still an issue and if this solves it, but it's worth a try and works fine for me:
Instead of adding the General Width and Height parameters, add the Width and Height parameters from an actual window object, these are called A and B.
(On the second image with the loaded parameters you should see the length icon instead of the arrow.)
edit: I only see one screen shot image from the ones I tried to share. Oh, well... If you have questions about how to add parameters from objects, let me know.
macOS 15, ArchiCAD 26/27/28 (USA)
first ArchiCAD: 6.5
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Duane,
This issue should have been fixed in ARCHICAD 21 update 5021 (fix #230091), and the released version of ARCHICAD 22 (3005).
Please make sure you have the latest build installed (7000), and if you still have this problem, then send me a PLA and a picture of where this issue is, so that we can take a look at what we might have missed.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
