interactive schedule problems
When I create an interactive schedule I cannot produce a schedule with names of the object or items captured in the schedule. Recently I am trying to help out the estimating department a bit and they want to know which item is which item is which.
11 REPLIES 11
I got it. It is the ID Peramiter under the General heading. I must have been over looking it all day. I really do apreciate your help Tom. You have been a tremendous help today.
TomWaltz
jcude wrote:
I don't have a peramiter under the heading called fill. All i have is "Cut Fill" and that is the 2d fill in the wall. Are we still in the edit settings box and under field? This is where I am looking and I don't see it. There is also a fill under general but it is the same as the above.
I'm sorry. I thought you meant you wanted the name of the Archicad Wall type (which is Cut Full), not the name you gave the wall (which you are right about, is element ID).
Tom Waltz
