‎2005-08-19 06:50 PM
‎2005-08-19 09:19 PM
‎2005-08-19 10:40 PM
jcude wrote:I'm sorry. I thought you meant you wanted the name of the Archicad Wall type (which is Cut Full), not the name you gave the wall (which you are right about, is element ID).
I don't have a peramiter under the heading called fill. All i have is "Cut Fill" and that is the 2d fill in the wall. Are we still in the edit settings box and under field? This is where I am looking and I don't see it. There is also a fill under general but it is the same as the above.
