2016-02-24 05:28 PM
2016-02-25 08:14 PM
alemanda wrote:Does anyone have a tabulated txt containing the numbers of Masterformat 2014?
The most "difficult" and tedious part is to prepare the data.
But I found a way ...
2016-02-25 08:31 PM
2016-02-26 11:38 AM
laszlonagy wrote:For me it didn't work. When I close archicad and open again it I don't see the new xml IFC rule set, even if it has a new name in the folder.
However, you may have to restart ARCHICAD for it to read changes made in the XML file. So if ARCHICAD is open, and you modify the XML, you should quit then restart ARCHICAD. For me that worked and it read the changes in the XML file.
2016-02-26 12:10 PM
2016-02-26 12:24 PM
2016-02-26 12:46 PM
2016-02-26 12:46 PM
alemanda wrote:Yes, that was probably the problem.
Yes. I was modifying the xml file in the program files folder.
Now I'm working in the user folder.
I reached the 12 division...
2016-02-26 08:04 PM
Erwin wrote:We are very, very late to the game here. Unfortunately. :- (
Seems odd this is not part of the US / Canada template.
We've got the local Dutch classification systems (and then some) in the dutch localisation.
2016-02-26 08:31 PM
2016-02-27 10:46 AM
